Question about Linksys Wireless-G Broadband Router
Can I safely disconnect my router at night for security reasons?
Can I safely disconnect either my modem or unplug my router at night for security reasons, or will I experience network connection isses the next day? Will my ISP get mad and 'punish me' because they don't have visibility if I'm not connected? Sometimes renewing my IP address is complicatd, when it should be simple!!.
  • 2,878 Answers
Disconnecting is your choice. No one will mind. Draw back is the possible loss of IP lease.
Go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it.
Posted on Nov 30, 2012
Benimur
  • 6966 Answers
SOURCE: laptop can not connect to router
If you care to try, manually enter IP settings in your laptop as follows:
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
DNS - whatever your ISP is using
In your Internet Explorer >
Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 24, 2007
  • 8 Answers
SOURCE: TP-LINK WR642G Problems with wireless connection.
Is your wlan & internet light lit?
Posted on Sep 09, 2008
  • 173 Answers
SOURCE: my linksys router will not connect to the internet
Reset your rourter, with a pin or a paper clip for 30 seconds and disconnect power and wait for 30 seconds and reconnect it back and check if the power light is lit up in your router first..if yes, connect the modem cable out to the wan port of your router, and check if the wan light is lit up in your router, if yes connect a lan cable from the number 1 lan port of the router to the desktop pc and check if the lan 1 light is light up if yes the router is working properly, then check for the ipaddress in your desktop..if not your router might have gone bad..if you have any doubts rever back..
Posted on Oct 23, 2008
SOURCE: Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Posted on Mar 13, 2009
eduverna
  • 7 Answers
SOURCE: configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Posted on Apr 13, 2009
Linksys E2000 keeps disconnecting
Disconnect the power from the linksys for about 30 seconds then plug it back and see if it stops dropping. Most times the dropping occurs if you turn the modem and router off at night then when you turn them back on the router boots up faster than the modem and that will cause it to drop. Power outages also will cause the problem if the router boots up before the modem.
If unplugging the router and waiting 30 seconds does not solve it then unplug both the modem and the router. Then plug the modem back in and let it boot up for a minute or two, then plug the router in and let it boot up.
Jun 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Icon at bottom says not connected but it is connected. It is intermittent. I constantly have to disconnect and then connect. it only works for awhile. had the router for 8 months never had a problem. I...
I would suggest unplugging the power to the modem and router, plugging the power into the modem back first, then your router. If this does not solve your issue, try bypassing the router and using just the modem. If the problem keeps happening without the router then there is an issue with your internet service and you should contact your ISP. If you find that this just happens only with your router, then there could be a number of reasons why this is happening. Try resetting the settings on your router by using a paperclip or pin in the back. You will need to configure your security and other settings if you do this so beware. Hope this helps!
May 26, 2011 | Computers & Internet
Trying to connect to online gaming wit ps3 took 5hrs to get it to accept ip address now saying error code but wen we shut router don it say system diconnect wat must i do to correct the problem
The reason it doesn't say system disconnect is because your just unplugging the router, you have to unplug the modem too. You probably should do a factory reset on both the modem and router.
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Why does my belkin g wireless modem router f5d7634 always disconnect every hour? i already turned the firewall off and yet it still disconnects from the internet. the globe led does not turn off but i...
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
Oct 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My belkin n route is unsecured how do I fix this problem
No, you're not safe.
Disconnect your router from your cable-modem (or DSL-modem).
Reset your router to "factory settings", which _are_ safe.
Mar 22, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
My cable modem is not recognizing my router/phone adapter.
Try turning all items off including PC, unplugging all including PC. turn on modem, turn on router then boot PC
Jan 04, 2009 | Arris SURFboard Cable Modem
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
When I try to reinstall my router I can't get beyond the first step as the disk thinks our computer is not connected to the internet when it is. It convinces my computer that it is no longer connected....
Step 1: Turn off your computer, router, and disconnect the power to the modem.
Step 2: Connect one cable between the modem and the router's internet port
Step 3: Connect another cable between the router and the computer.
Step 4: Turn on the computer, then the router, then the modem - in that order.
Step 5: Now try running the setup disk.
Explanation: The modem has a security feature that disallows more than one device from connecting to it at one time. Once a specific device is connected, the modem expects that device to be connected at all times. If you unplug your computer from the modem and plug in the router without disconnecting the power to the modem, the connection will be rejected. This probably explains the reason for the error message you were receiving.
Furthermore, you do not need the installation disk in order to install your router. Open your browser and type http://192.168.1.1 in the address bar. A username and password screen will appear, the default is usually admin/admin for both, but if that doesn't work just try admin in the password field. When you have successfully logged into the web utility, you will be able to alter the settings at your discretion. For the most part the router will work upon proper cable connections, however you will want to enable security features to prevent attackers from gaining access to your computer.
May 04, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
142 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
