Question about Yamaha HTR-6130 Receiver
Front left and right speakers don't put out sound
I just bought the yht-290 system with an htr-6130 reciver. the front left and right speakers work but only when I plug them into the surround left and right speakers. I can't seem to get the reciver to know what speaker configuration to use
Hit the button  "speakers/a/b/off" on the left hand side of the front panel until it shows that "speakers b"  are turned on.
Posted on Jan 18, 2009
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
I have a htr 6130 yamaha reciever and when i hook my five channel home theater system it plays for a while then when i turn it up to almost max it turns the unit off completly... how do i hook up my
Hook all the positive and negative wires correctly and read on the speakers and make sure you have them all in the right spot and if that doesnt help its probably because the reciever is maxed out wich is triggering a kill switch wich some recievers have as a safety feature so you dont blow your speakers
Dec 18, 2012 | Yamaha Audio Players & Recorders
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Receiver displays Dolby Digital while watching TV, but only 2 front speakers work. This is the case on only certain TV stations. I have a Yamaha HTR-6130
Depending upon transmmission bit rate, if the transmission is > then 6130 bit rate it will automatically change to 'STRAIGHT' mode and in this mode only two front speaker will work.
Oct 15, 2009 | Yamaha HTR-6130 Receiver
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
I am looking for a manual to a Yamaha YHT-390 Home Theater System. Help! Thank you.
http://www.yamaha.com/yec/products/productdetail.html?CNTID=567702&CTID=5000800&RLTID=1505&DETYP=RELATION
please download HTR-6130 for your YHT-390 manual. you may have to fill some info before you can download, please do so. let me know if there is any other thing i can do.
Apr 06, 2009 | Yamaha YHT-390 Theater System
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
459 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
