Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Weak spark very little spark
  • Poulan Master
  • 14,417 Answers
Check the wiring going to spark plug,check the other end to see if it's got a good connection,or it may need a new or rebuilt carb,took mine to shop,sat up for awhile,but was fairly new,they said I need a new carb,that they had to order parts,then called back and said the parts were no longer available,so I went and bought a Stihl.
Posted on Dec 02, 2012
X-mark lazer zero turn is missing on one cylinder. What could be the problem
Possibilities are defective spark plug, weak or no spark, too little or too much fuel, no injection at all, intake air leak, compression leak...
Jan 02, 2017 | Cars & Trucks
Has spark, rebuilt carb.,won't start, new plugs.....
only leaves compression
bad fuel ...air filter ..weak coil
if it will start if you toss a little petrol down the spark plug hole
its just a carby problem
Jul 01, 2016 | ATVs
Kohler Self-propelled Mower Weak Starting
Tighten the control cable where it should be set and if your engine runs slow and sputters with not much revs before you tear anything down take off the fuel bowl and clean it out as well the bolt that holds the bowl in place should have little holes in it these are fuel jets These have to be clean to operate properly. I use air compressed air to do this, and put back together and make sure the gasket is in the proper place when you do it.
Hope this works for you. I have good luck with this.
Oct 05, 2014 | Garden
94 5.7 falles on face boggs down then clesars up a little runs nlike junk. good cap and rotor plugs wires and new fuel pressurs regulator filter what am i missing ?????????????????? HELP
Incorrect timing? Weak spark (coil)? Low fuel pressure (restricted filter, fuel pump)? Incorrect spark plugs ? Low compression? Worn out camshaft (insufficient lift)? Spark advance (ignition module)? ECM?
Dec 28, 2013 | 1995 Pontiac Grand Am
Bmw r 1100rt 1996
replace plugs or maybe coils
May 28, 2012 | 1998 BMW R 1100 RT (ABS)
Have 4500 miles. Put rear wheel on ground and take off NO POWER. With rear wheel up in the air Power is fine.
The things that will cause "no power" on a two stroke are; dirty air filter, little oil in the transmission, rusty kinked up chain, partially plugged up exhaust port (carbon build up), bad crank seals, brakes are dragging, weak spark (install a new spark plug), weak coil.
Aug 04, 2011 | 2010 Tomos Streetmate
Chainsaw wont start. new plug has a little spark.
The engine case needs to be removed to expose the flywheel and ignition module. Check the module pole gap to the flywheel magnets with a thin business card for a gauge. If the gap is excessive, that can give a weak spark. If the gap appears to be correct, then it is probably time for a new ignition module. Make sure the spark plug is gapped at 0.020" before condemning the module. The spark should be blue and snappy. Check it in a dark area. Hope this helps!
Apr 17, 2010 | Garden
Weak spark
If there was a probem with the coil the extra loading from the short circuit may have caused a problem with the trigger coil for the main coil. I don not have the spec but this value can be check with an ohm meter. Let me know how you make out...
Sep 25, 2009 | 2003 Yamaha YZ 125
'96 Jetta,2.0l, hard and no start
Replace thye Ignition Switch.;
Jul 07, 2008 | 1996 Volkswagen Jetta
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
131 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
