Question about Nilfisk gwd 220 critical wet/dry vacuum,20g,2.4 hp
Week suction - Nilfisk gwd 220 critical wet/dry vacuum,20g,2.4 hp
    New Friend:
    Problem Solver:
  • 12 Answers
Have u checked 4 clogs
Posted on Dec 01, 2012
DC25 no suction at head?
Hi there, it's Jack at Dyson.
I'm not sure from your question how you're testing the suction at the cleaner head. For safety reasons we'd strongly advise against placing a hand underneath the cleaner head. This is not a good way of testing suction - the soleplate needs to form a close seal with the floor surface for high pick up. It's normal for the suction to feel stronger through the wand and through the cleaner head inlet as the suction is concentrated over a much smaller area.
If you place the cleaner head on a sheet of newspaper, then run the machine with the brush bar turned off, you should see the newspaper sticks to the cleaner head, as it's able to seal with the soleplate.
You might also like to take a look at our online Support guide, to make sure there's nothing blocking the machine which you may have missed: http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
If you have any further questions, it would be worth giving our freephone UK Helpline a call to run through some diagnostic checks with one of experts. You can reach us on 0800 298 0298 - we're on hand to help from 7am-10pm, 7 days a week, and calls are free from UK landlines.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 21, 2013 | Dyson DC25 Vacuum
My Dyson DC14 Animal doesn't have the suction it used to. The piece in the back on the bottom - a flap it appears - stays open now, causing the machine to make a louder noise than usual. At first, if I...
Hi its Darran at Dyson.
Having had a look at a DC14 here, I am unsure as to the part you are referring to. So that we can help you further, please contact our Helpline free on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Please have your machine with you when calling.
Kind regards
Darran
Customer Liaison
Apr 21, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suction is not as strong
you may have a clog in the lines.
check some Maintenance Cloths and run them through your lines and you should see some improvement.
If you still are having problems, contact your local vacuum shop and see if they do maintenance calls for central vacuums.
Apr 15, 2010 | M&S Systems FX-3000 Bagged Central System...
No suction in the hose on dyson dc24
It sounds as though the hose is blocked. I would recommend following the blockage procedure. If this does not resolve the problem, please call our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
Mar 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Suction stopped working immediately
There is a hose on the unit. Disconnect it at both ends. Stretch it out. Look down it. If you can't see down it, rod it out.
May 28, 2009 | GE Vacuums
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Nilfisk gwd 220 critical wet/dry vacuum,20g,2.4 hp Logo
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
