Wd-52725 I have has a rapid blinking timer when pluging into wall outlet.then it goes off so I can turn on t.v .it goes through the normal turn on process..no picture i get sound? Bulb is good.lamp ballast good no humming/buzzing from color wheel.but after awhile it well shut off and then calls for the lamp?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Do the self check (hold menu and source for 5 seconds or more and release both) power light will blink a 2 digit error code like 1 blink, 2 blinks and pause and repeat it several times.
Posted on Dec 22, 2012
SOURCE: Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Thanks for your solution. This is a problem with color wheel. I could not fix it by myself, so my friend will try to fix it next week.
Posted on Dec 11, 2007
  • 184 Answers
SOURCE: hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Posted on Feb 17, 2009
Axle80
  • 73 Answers
SOURCE: hlp5063w 50'' DLP samsung
Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
Good luck.
Posted on Mar 11, 2009
ZaneD
  • 41 Answers
SOURCE: Mitsubishi 52725 52525 Red Light turns on
the problem might be the thermal sensor on the light engine. with all the work you have done on this i would suggest taking a look at the thermal sensor. these are known to go out.
Posted on Apr 19, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a blinking timer light and my tv wont turn on
the problem with this tv is the contlor box , there about 12 capacitor that need to be replace , but some times the eepron is bad , normal repair on this unit is $450
Aug 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
