Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune tl washing machine spin cycle
I have a neptune TL washing machine that is 4 years old and is not completing the spinning cycle. I have contacted a local repair shop approved for Maytag and was told no parts are being made to fix this issue. I am at a loss since this is an expensive machine and supposed to be reputable. What can be done to fix this machine?
  • 2 more comments
  • Anonymous Jan 15, 2009
    I have a Maytag Neptune TL washer that does not complete the spin cycle. It makes clicking sounds while spinning and displays error code dc when there are 10 minutes left in the cycle. The repair person said it needed a new clutch, app. $300 for the clutch and repair. Have to wait a week for the part because they do not carry many parts for this washer even though they are a Maytag service dealer. Repair guy said they dis- continued making the Neptune series because of too many problems. Also have the matching dryer with drying center on top. It broke 4 months ago. Took about 10 visits to fix that problem.
  • gdave44 Jan 23, 2009
    I was optimistic with this one, but there appears to be too much damage to salvage.
    I bought a used neptune TL set for a hundred bucks figuring even if the washer doesn't work out, the dryer's at least worth it.
    I pulled the clutch per dh1200s' instruction and lubed up the whole thing with WD-40. If it worked, I'd take it out again and use a lithium grease. Alas, it didn't work. No change, speed would get up to 48 RPM on all three spin tests and end with a uC code.
    I figured I'd delve a little deeper. I pulled the tub apart and recovered an old drivers license, several paper clips, and a bowl full of change (some of it destroyed physically by the washer). So at this point, I'm figuring the bearings are shot in the base of the tub.
    With the clutch attached to that center shaft and nothing else in the tub, the spin test shows it now gets up to 60ish RPM but still fails with a uC code. The spring inside the clutch seems to be in good shape (corrosion free) and tucks up neatly against the outside wall.
    Any ideas of what else I can look for before I haul it off to the dump Saturday? I don't mind spending quality time tinkering, but I'm not about to throw money at it until I'm absolutely certain. And then it doesn't take much to exceed the value of the unit.
  • mother26 Jan 24, 2009
    I just had a repair technician come who told me it was not worth fixing my washer which has the same problem. With a clicking and grinding noise during the spin cycle and the dc light appearing during the spin cycle. After contacting another technician I was told that it was the clutch that needed to be replaced for the noise and for the dc code it is the tub sensor that needs to be replaced. The sensor is apparently easy to fix but not the clutch. Have any of you replaced either of these parts? And if so was it difficult? After fixing the problem has your machine worked and if so for how long?
  • dh1200s
    dh1200s May 11, 2010
    What error codes do you take when the machine stops in spin cycle? Can you verify that your machine is a FAV6800A model? My brief experience is on this model.
    Do you want to try to troubleshoot and attempt the repair? The FAV6800A from my view is very repairable if you or a friend has basic mechanical/electrical skill sets. The bulk of cost are labor if you can DIY the repair I feel it's worth a try before you junk a $1K machine. Mine was purchased in 7/05.
    If you are taking dc/UC codes in the display when the machine stops in spin cycle it may be similar to my issue. I had a clutch that needed to be re-lubed to stop dc/UC fail codes in spin cycle. Cost of repair for was around $5 for a can of WD-40. I estimate I’m around 25th load of different amounts of clothes with no fail codes in spin cycle.
    Parts supplier just a few.
    http://www.pcappliancerepair.com/model-d...
    http://www.appliancepartspros.com/partse...
Mother26, I have a fair amount of experience with mechanics and have repaired a few washing machines and dryers in my past. For me, both components are easy to replace. Your repairman would have an equally easy time. I'd estimate an hour to repair and verify. Your trouble comes in is the $122 for the replacement clutch and the $82 for the tub displacement sensor. And that's assuming there's no damage to anything else so far.
In my case, change the previous owner didn't remove from pockets destroyed the clutch, transmission, and pump. and somehow spillage caused the tub displacement sensor to short. Overall, far too many parts to make repair equitable.
Keep in mind, this is, in the opinion of many, a failed design on the part of Maytag. Ultimately, it's a toss up on how confident you are that your current condition is the limit of your problems.
Posted on Jan 24, 2009
  • 335 Answers
Here is my solution, if you feel you don’t have basic mechanical skill sets to take this on try a family member or friend. What I describe below is a chronic problem with this model and it is repairable with little cost if the issue is similar as mine. Cost of my repair was $5 for a can of WD-40 and a couple of hours of work. I’m at the 30 load mark with no dc/UC error codes in spin cycle not sure what codes you have but I'll bet dc, UC or both.
“”I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/UC errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley, just follow the service manual removal steps to remove the clutch pulley. Pull the plastic cover off the clutch pulley and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with good light grease. It took a few tries for me to get the clutch pulley to stay on after re-install and power up; getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix; I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle; it is a tight work area. I did not want to junk 4 yr old $1k machine without trying a fix. If you want to work on this model get the service manual, I found a link on this site, good luck!””
Here is the SM for the FAV6800A/FAV9800A http://www.servicematters.com/maytag_library/docs/16022808.pdf
Posted on Jan 11, 2009
  • dh1200s
    dh1200s Jan 23, 2009
    Have you checked to see if the tumblers are turning when the washer is in spin cycle. In spin cycle the wash basket rotates CCW and the tumblers must not rotate, If they do you will throw the DC/UC unbalance error unless the wash basket is empty. See this post;
    http://applianceguru.com/forum2/13242.ht... Thur Jun 21st, 2007 03:59 pm. This is what clued me in to the clutch not operating properly. From your post it sounds like your testing with a empty wash basket and throwing unbalance errors. Did you test the Tub Displacement Sensor per the troubleshooting guide/SM?
    I agree with you about soaking money into the machine. I and a few other folks got away with the WD-40 clean/lube job. I would love to pick up a machine for $100 for parts. Good luck.
  • dh1200s
    dh1200s Jan 24, 2009
    Hello mother26
    There is a Tub Displacement Sensor check in the troubleshooting guide which should be in the console of your machine this will help you diagnose if that is the issue. You can release the top of the washer (not the washer lid) and start a spin only cycle (no clothes in the wash basket) and observe the basket. The basket should begin to rotate CCW and the tumblers in the basket must not rotate, at most they will rotate half a turn. If they rotate as the wash basket rotates CCW in spin cycle then you have a clutch issue. The fix may be as simple as mine which was removing the clutch clean/re-lubing with WD-40. I have read other post where one person had a broken clutch spring that he repaired. If you have basic mechanical skill sets you can try a fix, I felt it was worth a try for me. I did this back in mid Dec, and have gone thru 30+ loads. Loads were single dish towel to heavy bath towel loads. The grinding noise might be coins under the tumblers, I hope it’s not the transmission. Maybe other forum members chime in.
    The servicematters.com site has a Tech Bulletin TDL-0062-B about clutch issues with this machine along with other info on your machine.
    From the trouble shooting guide; The Trouble shooting guide speaks of limit marks on the sensor. I would just try to pull the tub as described below and see what your results are, I’m betting on a clutch issue, Good luck.
    1. Enter the Service Mode by pressing and holding
    the Enviro Plus and Spin Only keys for three
    seconds.
    2. Press the Super Wash key.
    3. Press Delicates.
    4. Push tub to back right corner. Display will
    show “UO” (Unbalance open).
    5. Press Hand Wash.
    6. Pull tub to front left corner and push down so
    sensor collapses . Display will show “UO” (Unbalance open).
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune TL ( purchased in 2005) is grinding during the wash cycle only. Spin cycle is quiet. Once the entire wash/rinse spin completed I opened the washer to retrieve the load and found a piece...
Jose,
I'm an owner of three FAV6800A machines and I'll respond to help because you want to roll up your sleeves and try to save your $1K machine.
1st No direct links Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with.
Post in that forum your machine Model which I assume is an FAV6800A (LED Console) or FAV9800A (LCD Console)
Include the first two digits of you machines model number. That is the series of your machine.
Give a description of the issue as you did here. I hope the grinding is during wash/agitate if so it may be something as simple as tumbler removal to clear out debris. If the grinding is in Spin Cycle it could be a bit more work like Outer Tub bearing failure.
The Forum in my opinion is geared more toward the DIY owner as I am and as you sound. The forum is free like this and my support is free..........Good Luck D*ick
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune tl- about 6 years old. Wont finish out the final spin cycle on any setting and also sounds like tub/drum is hitting against side of machine. It also rocks like crazy. Shows the code for...
You have a Clutch malfunction common problem with the FAV6800A and FAV9800A TL's. Owners very seldom report all the conditions of wild tub swings. You are on the ball with info feedback.
See if this post Clutch Fix will get you started.
Post back if you have questions or need help.........Rich
Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Won't advance
richard_f777
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Washer not finishing it's rinse/spin cycle
Run any load - large or the least bit bulky (like sheets) on the "BULKY" cycle. It takes longer, but the machine completes the wash. This shouldn't be the way it works. I love the Neptune TL for its retro look and lack of Maytag's classic big cranky knob. Too bad it runs like ****.
Feb 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,381 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
