Question about Dryers
I have a Kenmore Elite Dryer Model# 110 60052991 that starts but after running for about 10 minutes it shuts off. what could be causing this?
It heats great when it running and if I push the cancel but and restart the dryer it starts up again but shuts off after 10 minutes once again.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
The model number you posted is for a washer.
Posted on Dec 01, 2012
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite gas dryer - model # 110 70052990. Just hooked it up after a year of not using it and it continues to shut itself off on Normal dry (begins at 40 minutes) and shuts off at 38 minutes....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer 63942 Push on button, turn the timer to 30 minutes.Within 10 minutes the dryer shuts off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 11, 2010 | Kenmore 63942 Dryer
I have a Kenmore Elite model # 11063032101. It
If exhaust is blocked or restricted from back of dryer to outside of home it will cause the dryer to over heat the high limit switch. Repeated overheating will weaken the over load switch and it will need to be replaced if normal operation can not resume without restriction. Sea Breeze
Mar 26, 2009 | Kenmore Elite HE4 Electric Dryer
Feb 08, 2009 | Kenmore 62602 Electric Dryer
May 17, 2008 | Dryers
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
