I think i blew a fuse cause my wires touched and now my sharp 1-bit digital home theater sd at1000 want cut back on help...
  • 298 Answers
SOURCE: SCHEMATIC
You can find the service manual in the link below.
SD-AT1000H Service Manual
Posted on Mar 13, 2008
  • 4234 Answers
SOURCE: Sony Home Stereo Fuse
When the wires touched, the output transistors overloaded before the fuse had a chance to blow. The outputs need to be changed. It is possible that the driver stage for the final outputs is bad also, but there is no way to know that without removing the bad outputs. Figure on $25-$45 in parts for this repair.
Dan
Posted on Aug 26, 2008
killer_clown
  • 86 Answers
SOURCE: i blew my fuses on my ht-400 digital home theater system
Radioshack has a good selection of fuses, an all you do is take the one out of the system take it with you an they will help you find the fuse ur looking for, an you would be good to go
Posted on Oct 22, 2008
  • 449 Answers
SOURCE: samsung ht-z310 sound problem.
First check the mute button. hope this help
Posted on Dec 17, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
Looking for 1 bit home theater SD-AT1000 manual
I know of none! you need at least 5 bits to make sound.
Jul 15, 2014 | Audio Players & Recorders
Sharp sd-at1000 turns on for 1 sec then turns off
Without looking up this model number, it would appear that your amplifier has DC Offset(meaning a damaged amplifier). For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 21, 2013 | Sony DAV-SA30 System
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
I took the cover off of my dvd player to clean the lense. Upon putting the top back on I touched the lid to the back of the power button on the inside and got sparks and blew the fuse. I have tried...
A semi-conductor has shorted. It will continue to blow fuses until you replace the shorted component. If you have electronics background, you can locate the short with a multimeter and a schematic diagram.
Dec 14, 2010 | Panasonic Audio Players & Recorders
Toshiba home theater SD-KT50SU shuts off "PROTECTION"
Ok what this means is that some wires are touching in the back of unit causing a short (your system is protecting itself) look for wires touching and make sure its hooked up right
This should fix ya!
Dec 13, 2008 | Sharp XLDV60H Shelf System
My kenwood surround sounds fuse blew and know theres no sound?
Never bridge a fuse in your life again this is the wrongest thing to do.. Check first there should be IC's skrewed onto a heatsink, some surrounds uses Transistors you should be able to see the burnt ic it will be cracked or burnt, replace that replace fuse if fuse still blow then replace all the ic's on heatsink..
Dec 07, 2008 | Koss KS3102 System
Dan
Aug 26, 2008 | Audio Players & Recorders
SCHEMATIC
Mar 13, 2008 | Sharp SD-AT1000H System
24 people viewed this question
 Grubhead
Grubhead
