Question about Troy Garden
Is there something that can be put in the fuel to keep the fuel line from disintegrating?
Used my Troy Built Gas Trimmer and put it in my shed. Approximately 1 and 1/2 months later went to use it again and the fuel line had disintegrated. Repair shop want $78.00 to put a new line in. Can I do it myself and is there something to add to the gas/oil mixture which would prevent this from happening again? Or do I have to drain the tank each time I put it away?
    Scholar:
  • 144 Answers
You can add a fuel stabilizer to the fuel to prevent that from happening. You should always add the stabilizer to new fuel and it can be used in all of your engines, everything from a string trimmer to your car. The ethanol in today's fuel is causing many problems, especially with 2-cycle and 4-cycle engines. You can buy Star Tron fuel stabilizer from PartsBuggy.com. A good size is the 8 oz bottle. It treats 48 gallons of fuel with one bottle.
Posted on Dec 01, 2012
#1 Taper
  • 1041 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: My troy-bilt TB425CS gas string trimmer gas lines
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Posted on Aug 15, 2009
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
  • 19 Answers
SOURCE: My weed eater trimmer gas lines disintegrated.
There might still be air bubbles trapped in the new gas line. First make sure that is enough gas in the tank. Try pumping the dome shaped transparent rubber to get the air out and let the gas in. Try starting again.
Hope this helps!
Fix14
Posted on Jun 16, 2010
rycgl
  • 1545 Answers
SOURCE: Troy built weedeater 70ss gas engine will not run
The needle and seat (esp. the needle) meter the amount of gas/oil that is being allowed into the metering chamber of the carb for use by the engine. Your problem does seem fuel related. These carbs are very temperamental and scare most folks. A guide to how they work can be found here: www.zamacarb.com/pdfs/TechGuide_2007.pdf
This will give you an understanding of what exactly you are dealing with. You may only require a diaghram kit or rebuild kit to get the carb back to the functionality it was designed for. That info can be found here once you know your carbs exact model number.
http://www.m-and-d.com/zama_carburetor.html
A troubleshooting guide for these carbs is included in the first pdf file, look it over maybe and see what you think. Post back maybe later after going to school (doesn't hurt to learn how they work). We will be here. I know you want to use this machine (its the growing season) but there are so many things that can be wrong that it needs to be narrowed down...sounds like fuel starvation and just may need to clean the inside of the carb with something like the brake parts cleaner spray. It is non-flammable and doesn't damage the sensitive parts inside these carburetors the way ehanol and harsh carb/chokle sprays and strong solvents due...NEVER soak these carbs in a "Gunk style" carb cleaning tank....it will seriously damage sensitive internal parts and check valves!
Posted on Jul 10, 2010
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
Trimmer is producing alot of white/blue smoke, got it to start and it will keep running, but the smoke seems excessive when using it. Not sure what the problem is.
This engine does NOT used mixed gas at all! It uses straight unleaded gas. If your using mixed fuel of any mixture ratio in the engine it is really going to smoke badly. What fuel are you using please?
Kelly
Jul 01, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I bought a Troy built tiller. used once two years ago. then it has been sitting in a shed. It had old gas in it. I drained gas tank. I am getting a spark. when I pour gas in air breather, it starts, but...
I have had good luck using an engine starting fuel, sprayed into the air cleaner/intake. Any auto repair store will carry this product. CAUTION, HIGHLE FLAMMABLE!!!!!!! Many mechanics frown on using starting fluids, but I have a bad shoulder & that is what I do on the 3rd pull.
Louie Almond
Mar 27, 2011 | Troy-Bilt Pro-Line 160cc FRT Tiller
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I put trimmer away after using, and the next time I took it out it would not start, I changed the spark plug and the gas and still it wont start., the kill switch on the handle check out ok with a meter?
I want u to make sure a critter hasn't built a nest in the exaust hole.
Use something to get in there and scratch around with, and blow out with some air. If its not exausting it won't start. Also make sure the fuel lines are not cracked or loose and letting air bubbles in, she won't start then either. Hope I helped.
ballping
Jul 26, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Fuel line for Toro trimmer
Hello:
You can Purchase Fuel Line for Trimmers and All Lawn Equipment at your Local Small Engine Service Center or your Local Automotive PArts Retailer.
Take a Piece of the Old Fuel Line so you Purchase the Correct Size.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 26, 2009 | Garden
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
93 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
