Question about LG / SteamWasher Series WM2501HVA
Remove door seal on lg wm2501hva washer
How to remove door seal so I can clean gunk buildup under door seal
    Top Expert:
  • LG Master
  • 9,472 Answers
Take a look at this video.
Posted on Nov 30, 2012
  • 236 Answers
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Posted on Mar 16, 2009
SOURCE: LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Posted on Aug 21, 2009
  • 7 Answers
SOURCE: how do you remove the rubber seal in a front load
There is a spring band on thr fromt lip of the seal and the seal closest to the tub.To remive use a flat slim tool to lightly pry up on the band and it till pop off.Same with the inner band.
Posted on Oct 01, 2009
SOURCE: I have an LG washer that smells like rotten
Run a cup each of baking soda and vineger thru a hot wash. Might have to do this a couple of time if smell really bad.
Take out the unit where the liquid soap, softner, etc goes and clean by hand.
Soak a cloth in vinegar and clean the inside of the rubber around the tub.
And finally DO NOT LEAVE THE DOOR CLOSED IF NOT IN USE.
Posted on Oct 31, 2009
apart4u
  • 213 Answers
SOURCE: remove and replace front door seal on LG wm2277HS front loader wa
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
I am getting black streaks on clothes after washing.
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
Apr 09, 2015 | LG WM2301H Washer
Washer leaving black gunk on clothes
The agitator and s/s bowl needs to be removed for cleaning.
You need to use a pressure washer to remove buildup on s/steel bowl
The bucket aka tub needs to be cleaned also check for items that may block or jam pump at the bottom of the bucket.
reassemble your machine, it should do a better cleaner wash.
Feb 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
Lg washer wm2501HVA light stays on
why my lllLG washer WM2501hva light stay on ????
Jan 29, 2012 | Washing Machines
Front door is leaking..I think there is gunk under the grey seal..can that be taken off and cleaned or anything?
If the door glass and the door seal are making proper contact there should not be a problem..The smallest gap, split or tear will let water out. A leaking door seal usually needs to be replaced by a tech....Nomess
Apr 02, 2010 | LG WM2487H Front Load Washer
I have an LG washer that smells like rotten clothes. My clothes come out smelling real bad. I checked inside and noticed that the rubber seal around the door is holding moldy rotton gunk. It's not self...
Oct 31, 2009 | LG WM2688HWM TROMM SteamWasher
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Kenmore goo/gunk
If it's a front load washer do not put to much soap in it!This can gunk it and cause the bearings and seal to go bad!
Follow the washer directions for detergent amounts.
PS . Please give me a good rating here on fixya.com
Thank You ngfam2
Aug 22, 2008 | Kenmore 44832 Front Load Washer
Cleaning rubber seal
Use a 1/2 cup of vinegar and pour it onto the rubber door seal.  Let it sit awhile then wipe dry.  The stains are very hard to get off once they're on.  You can also use baking soda to remove the odors.
Jul 21, 2008 | LG WM-2077C Front Load Washer
LG / SteamWasher Series WM2501HVA Logo
612 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
