Question about Dell UltraSharp 2007WFP Monitor
Display unstable s-video and composite switching back and forth
    Problem Solver:
  • 9 Answers
Tek the new data cable from market and se
Posted on Dec 04, 2012
The video 1 and video 2 display flashing simultaneously back and forth...cant play dvd cause it continually switches back and forth
Try a different resolution setting.
You can also try playing the dvd into another device to confirm dvd works fine.
Check output\mode of device as well.
I assume, you inserted another dvd and it worked fine, then you inserted the "questioned" dvd is it flashes back and forth.
Try another video mode or setting change on device.
Jul 22, 2014 | Televison & Video
Bought a Soney KDL-46EX500 last week. Still tring to get it set up. Got the digital local stations programed into it today. (finally) Now I can not figure out how to switch back and forth from locals...
Looking at a diagram of the back of your TV I see that you have only one Coax input. You will need to plug either your antenna or the DirecTV in one of the other sources available on the back of the TV.
According to DirecTV's website, their box also uses composite video cables and depending on the age of that box, may have an HDMI connection also.
Looking at the back of your TV, the composite video cable input is the top two rows to the right of the Coax input you are currently using.
Once you have both connected to different inputs, you can use your remote to switch between the sources and watch whichever you like.
May 03, 2017 | Sony Televison & Video
Hi there, everything seems to be working but there doesn't seem to be a signal going to the TV. Am just about to try using a HDMI cable. Do you think this will help?
What I did was initally hook up both the composite (R/W/Y) cables and the HDMI and switched between TV inputs until I found the display. Once I had the display (mine was on composite) I went to the settings, then display, and switched it to HDMI input. The screen went blank and I switched to my HDMI TV input and saw the display. I unplugged the composite and it was good to go. I also had to hold my finger over the power button for a few seconds when turning it on - I believe it resets the display to default, but it worked. Good luck!
In the event that it gives you a hard drive error shortly after, it's nothing to worry about. You won't lose anything and it will take a few minutes to run its course. Just make sure you never turn it off from the back of the system first, always shut it off via menu options.
Respectfully,
Don
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Is there a way to determine the output resolution as to be hdmi or composite video without being able to see anything? I am unable to use hdmi as there is no signal, and then composite video seems to have...
Plug in just the orginal cables, make sure there is no disc in the ps3, turn off ps3 with main power switch in back, then turn that switch back on. Now your gonna hold the power button, its gonna beep right away, then a few seconds later it will beep again, the light should stay green and that resets the display settings back to AV. If it doesn't work the first time, try it again, somtimes it takes a couple trys.
Aug 10, 2009 | Sony Playstation 3 (PS3) Console
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Sep 15, 2008 | Computers & Internet
Fuzzy, unstable display
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 15, 2008 | Sony GDM-C520K (Dark Gray, Gray) 21" CRT...
Dell UltraSharp 2007WFP Monitor Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
