Question about Health & Beauty
Breville Maxum hair clippers forgotten how to reattach blades
Cleaned blades and cannot re- fit the blades properly. The smaller blade falls out.
SOURCE: conair hc318d reassembly
you can buy another blade set for that model. Call 1-800-3-CONAIR
Posted on May 26, 2008
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
Posted on Jul 25, 2008
  • 7 Answers
SOURCE: blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Posted on Jun 01, 2009
SOURCE: andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Posted on Nov 19, 2009
  • 1618 Answers
SOURCE: The clipper blade adjustment on my Remington Hair
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at
Posted on Jan 26, 2010
Testimonial: "Thanks "
I am recently purchased wahl professional 1124 hair clipper in usa it is is very hard sound. How to less sound
make sure that the clipper blades are properly fitted
they will stand off the clipper body until they line up with the movement
turn on the clippers and gently press down on the blades to ensure full engagement
Apr 25, 2016 | Wahl Health & Beauty
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Oct 07, 2009 | Andis 01690 Hair Trimmer
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
Clipper Blade
the bottom blade has to be put back in place. Unscrew the two top screws and remove the top blade. fit the the bottom blade on the plastic piece. Replace the top blade and screws
Mar 19, 2009 | Conair HC100RCS Hair Trimmer
Oster Golden A5 Clippers will not cut
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Feb 28, 2009 | Oster Golden A5 1-Speed Universal Motor...
Health & Beauty Logo
309 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
