Myron & Davis AD-215 DVD won't play or eject
The unit power is on, disc comes up on screen with the option to click on Play, the Disc light which is usually Green when playing is now red. The unit was working fine I was playing a disc, then I switched the ignition off. When I switched the ignition on again later in the dayit started ok the unit it recognized the disc but when I clicked on the Play button nothing happens. I then tried to eject the disc but it wouldn't eject.
  • Tom Regan Dec 01, 2012
    Unfortunately I don't have a remote control for the AD-215 any ideas of where I could purchase one from?
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
Ikarus
  • 10 Answers
SOURCE: No valid disc
the codes might have got switched somehow (region codes.) go to this site www.videohelp.com/dvdhacks.php follow the instructions.....I hope this helps!!!!
Posted on Jul 24, 2007
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Posted on Feb 01, 2009
SOURCE: wont recognized disc
I got it work work with mine. Here's how: I removed the top cover and put in a disk to see what happens. I realized it had to be a motor problem because the dvd player was having trouble spinning the disk. I removed the part that had the motor and sprayed some air into it to clean it. It works perfectly now!!
Posted on Jul 19, 2009
Toshiba REGZA won&#39;t play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Will not read the disc
Ever get an answer on this? I just bought a vehicle with this player and it shows me loading.... Then nothing. Don't know where to get a replacement or repair.
Dec 01, 2013 | Myron & Davis AD-212 Car DVD Player
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Hi .."my Myron and Davis
The optical lens of your dvd is almost dirty try to use a cd cleaner. hope that this may help.
Jul 10, 2011 | Myron & Davis Televison & Video
I can load the dvd fine. The picture comes up onto the screen just fine so I know it's reading the disc. I don't have the remote control (it's lost) but pushing the play button on the unit should make the...
if the disc is read by the player the tittle menu of the disc should appear at the screen and the player is ok you just need a remote control coz some disc/program need to start through remote program
Apr 30, 2011 | Myron & Davis AD212
I have a Myron &amp; Davis AD256T dvd player and the problem I have is, Cant see video games from the rca the video game get froze on the tv screen from the begining and dont let me play
It could be a game console connection problem, make sure that your Yello RCA output is going in your Video input on the monitor or monitor receiver. You might have a power or voltage problem, if the wrong current or voltage is incorrect then errors and freeze ups can happen, the player wont support the wrong voltage going in. Check your power connections, Video out/input connections and check your voltages.
Good luck.
Make sure to vote and rate me if I helped you. thanks
Jun 13, 2010 | Myron & Davis AD-256T Car Video Player
Will not eject from Myron & Davis ad-212
Not yet, I am looking for a way from the controls to release the DVD which is probably locked so it can restart where it left off.
Sound may resolve after that, not sure.
What about getting the manual and user guide to help users find the answer???
Jan 21, 2009 | Myron & Davis AD-212 Car DVD Player
-Myron-Davis-Myron-Davis-AD-212
On my ad212 dvd system by Myron and Davis it has an attached fm radio modulator. It has 4 channels you can use and they corresponed to unused frequencies in the users area of travel . Mine is set to 88.7 fm and all I had to do was set the FM radio to 88.7 to get the audio playing on the dvd movie.
Nov 26, 2007 | Myron & Davis AD-212 Car DVD Player
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
