SOURCE: Poor photo copy when printing 4x6 glossy in cassette tray.
Set the Ink Intensity (Windows)
The Intensity
setting controls the amount of ink placed on the paper. The higher the
intensity the darker (more ink) the printed image will be. If the
Intensity setting is set too high, the printed page may become too wet
and curl or streak. Follow the instructions below to adjust the ink
intensity settings.
For Windows Vista
For Windows XP Home Edition
For Windows XP Professional Edition
For Windows 2000/Me/98
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
SOURCE: my printer keeps printing from rear tray when i
Most of those have a button marked feed switch and a picture with a LED that either shows rear or bottom tray. You need to select the right tray on the printer panel.
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
