03601-24-080 display isnt working
Display on harris printing press
  • 7,627 Answers
Wrong category
Posted on Nov 30, 2012
IF STATEMENT
Let x be the total number of hours worked. Let w be the total wage.
If x < or = 40, w=16.5 x,
Else w= 16.5*40 +26.5*(x-40)
Aug 31, 2014 | Office Equipment & Supplies
Hi there. A mystery error shows the Display of my Finepix S2 pro. Its like that: "o - -" or "o _ _" in the upper Display. Has anyone an idea for that? Best regards, Harry
Try resetting the camera by removing the battery for 15 mins. Replace the battery then go to the camera's Menu and scroll through the settings to set the Date and Time.
Apr 18, 2013 | Fuji FinePix S2 Pro Digital Camera
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
My HP photosmart C5180 has a Ink System Failure Error code 0xc18a0201. I tried the master reset - holding the ok and help buttons down while turning the printer on and off. That worked long enough to print...
The ink system failure message has a chance to be fixed or it may be a permanent issue. It
can be pointing toward a firmware failure in the printer and if that is the case the
following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration
Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to
“Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared.
Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the
“Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall
outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER”
followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK
INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the
initialization process is complete, the printer will print out a Diagnostic Page.
Good Luck!
As a side note if the printer cannot overcome the error the only printer still sold that takes 02 cartridges is the Photosmart C8180.
Apr 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Will not eject ****. the word SAFE appears on display window
Check the unit isnt on child lock, if the unit isnt on child lock, you may have a few different problems. It could be a blown component somewhere in the machine causing it to be on 'safe mode' as to prevent futher damage, normally this occours on the Power Supply Printed Circuit Board, Or it may be a simple isse as the dvd drawer or VHS deck assembly has an allignment issue and is also why it may not be ejecting. I hope this Helps. Good Luck.
Nov 25, 2009 | Samsung DVD-R135
Our Paser 8560n won't print, sz Fault code
Here is the info from the service manual
Harry
8500/8550/8560 PEST description
37,017.44: Deskew Clutch Disconnect.
The Deskew Clutch is not
drawing the expected power.
Oct 09, 2009 | Xerox Phaser 8560N Laser Printer
TruMotion Demo.
Hi Harry,
From the Picture Menu, the option at the bottom is Trumotion demo. Highlight this and press enter, turn demo off, press return.
Let me know if this helps and please rate this solution.
Lone99star
Jan 29, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
Delayed typing
On the far rt. side of the keyboaed is the print mode key, press it and the DP will go out on the display.
Hope this helps
DicktO
Dec 27, 2007 | IBM 3500 Typewriter
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
