Question about Gbc HeatSeal Ultima 65 Laminating System
GBC ultima 65 bad smell - too hot?
The laminator is suddenly putting off a stronger than usual "hot melting plastic" smell. Also the first laminate starts off with this yellow burnt looking crease/line all the way across the laminate. I think it is getting to hot but I do not see how to adjust the temperature. I recently had to wipe down the rollers using a damp 3m pad to remove some residue but I got rollers very clean.
  • vicki massey Dec 02, 2012
    Bad smell - too hot?? Cont. To clarify. I think the rollers are clean so I don't know what accounts for the very strong smell as if the plastic is burning. I think the plastic between rollers is getting too hot and that is why the laminate first starts with a yekkiwish brown burnt line running the entire length of the roller. Mt machine doesn't appear to have temperature controls and manual doesn't mention temperature. Any ideas how to adjust temperature? Or other ideas?
5 Suggested Answers
  • 11 Answers
SOURCE: My ultima 65 laminator is not sealing well on the
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
Posted on Mar 11, 2011
  • 5603 Answers
SOURCE: GBC Heat Seal H525 -
The problem would either be UNEVEN pressure of the rollers from one side to the other OR the roller sets are NOT parallel. The cogs should have NOTHING to do with it.
Posted on Sep 15, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
  • 3 Answers
I fix these machines for a living. As the machines age the heaters in the red rollers dont heat evenly and cool areas dont seal well. If you have a heat gun check the temperature along both roller. Some variation is normal but very cool areas that dont seal well point to needing new heaters. GBC machines work well but the parts cost a fortune. if one heater is going bad the other one is too, change in pairs ONLY, heater sets are near 300 bucks last time I checked:(
Posted on Jul 24, 2012
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Gbc HeatSeal Ultima 65 Laminating System Logo
160 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
