Question about Kenmore Washing Machines
Kenmore front loading 796.4127
Cold water pipe banging at start
  • 1294 Answers
SOURCE: cold water will not enter washing machine
Turn off the faucet in wall. Unscrew the inlet hose to examine whether there is clogging in the tiny screens. Both ends as well as machine input hose. Clear out properly. Open faucet to check. See that you have a "y" or "F" type adaptor for your hot and cold inputs of the machine. This is if you have only one faucet in wall for your washing machine. If this does not work you have to check your (plug off the wall first) wires to the inlet pump of your machine - this probably has come off or is loose. And if this does not work, your inlet valve could be defective.
Pl rate if helped.......
Posted on Dec 31, 2007
jsrock516
  • 5911 Answers
SOURCE: tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Posted on Oct 03, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Posted on May 15, 2009
  • 89 Answers
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
Posted on May 27, 2009
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have an LC front loader washer that has a water hammer problem when the hot water tries to fill the machine. It works fine with the cold water only. It makes my house pipes bang loudly and it is...
actually its a part that needs to be installed before shutt off valves you can find them at your local plumbing shopp lowes homedepot or menards or call a local plumber
Jan 23, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My Kenmore Elite front load washer is great but when it adds water, the water slams on and slams off. It does this multiple times per load. Our pipes are older and they bang with every load. Is it...
Check your water pressure at the sourse. Strong water pressure will cause banging noises from relay valves open and close. Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 24, 2010 | Kenmore 44102 Front Load Washer
Pipes are banging
you can purchase a "hammer arrestor" from any major hardware store and have it installed which should cure your problem.
Feb 11, 2010 | LG WM2277H Front Load Washer
Thumping sound when the water turns on or off? during a normal cold cycle, we especially hear it during the spin cycle. It's not the spinning action it's the water turning on or off that makes a pretty...
Sounds like you are experiencing "water hammering". When the water valve shuts off quickly, the water which was flowing in the pipe must stop, and the momentum of the water suddenly stopping can cause the pipes to rattle or bang. Adding an air chamber would cusion that, and eliminate the banging. I have seen some (at a local Home Depot) which can screw onto the hose right where it connects to the hosehold shut off valve behind the washer.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer will not fill with cold water and will just stop at the rinse cycle and buzz
Check your inlet pipe on cold water supply, When you dissconnect look inside where pipe fits onto machine you will see a small filter, if it is blocked take it out with great care and clean. always replace it. if your water supply is ok and filter is clear then it will be a faulty water valve. Good luck and feel free to give feed back ok.
John
Sep 03, 2009 | Kenmore Washing Machines
Washer bangs between wash cycle and first spin/rinse cyle
Sounds like you need a water hammer control in your Hot water line, usually it's teed into the line and is just a short length of pipe with a cap on it, acts like a shock absorber
Aug 22, 2009 | Kenmore 46462 Front Load Washer
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Water not coming into my HE5 washer
Check that there is water coming from water supply, if not lines can be clogged or frozen.
If water is coming to the machine, but not entering into the drum, then it is a faulty inlet valve, or a faulty control, have parts tested and replaced.
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Mar 10, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
155 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
