Question about HEALTHRIDER R60 SoftStrider Treadmill
Start R-60 can not get it started
    Top Expert:
  • HEALTHRIDER Master
  • 12,223 Answers
See the video and proceed according. God bless you
2) LUBE the deck belt
3) LUBE the rollers bearing too
4) Test the drive belt motor
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting HELP.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Posted on Nov 30, 2012
2005 Impala cruise won't hold speed. The cruise seems to work kind of.
Check the linkage at the advance to se if it is broken. Some are by mechanical connection and others are by vacuum. If vacuum you have developed a leak and must replace the controler to make it work again.
Mar 09, 2016 | 2005 Chevrolet Impala
Model 10AJB48A01. What are the specs for the motor starting capacitor?
it is either a 45/3 370vac or a 60/5 370vac depending on the compressor that's in the unit. if the unit serial number starts with 6936 it is the 45/3 if it starts with 6937 it is the 60/5
Jul 24, 2015 | Weather King Heating & Cooling
How do I input Degrees-Minutes-Seconds to convert to Degrees? Vice-Versa.
On any calculator, let's convert degrees-minutes-second to degrees and then we will do the reverse.
Let's start with the number of seconds in a minute - 60, so we must take the seconds and divide by 60 to get the number of minutes. Next, add the number of minutes. The number of minutes in a degree is 60, so we take this total and divide by 60. Now we add the number of degrees to get out final answer.
Example: 35 degrees 50 minutes 32 seconds
(32/60 + 50)/60 + 35 = 35.842222 degrees
Just out of interest, let's start with 35.842222 degrees and convert it to degrees-minutes-seconds. We know it is 35 degrees, the whole number. Now we have to determine the minutes and seconds. Start by subtracting 35 to get the decimal 0.842222. Now multiply by 60 to get the number of minutes. I get 50.5332. Subtract 50 from this and multiply again by 60. I get 31.9992, which rounds to 32 seconds.
Good luck.
Paul
Jul 06, 2015 | Texas Instruments TI-36 X Solar Calculator
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
Vibration between 40 and 60 mph
when did you have your tires balanced last. If it has been awhile have them re-balanced. Your description sounds like you may have thrown a weight.
Aug 03, 2012 | 2003 Suzuki Vitara
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
4.3 vortec on my s10 won't start. squirted starting fluid and it started, ran but sluggish. shut it off for 30 minutes not starting again
More than likely you have a fuel pump gone bad. Fuel pressure on the Vortec needs to be at 60 psi. Check your fuel pressure, and if lower than 60, replace the fuel pump.
Aug 19, 2011 | Chevrolet S 10 Cars & Trucks
Cranks normal wont start
bad spyder it sonds like
Apr 01, 2010 | 2000 Chevrolet Blazer
Oil pressure gauge moves too much
Have your oil sending unit checked, this part is not to expensive
Jun 16, 2009 | 1994 Jeep Cherokee Country
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
HEALTHRIDER R60 SoftStrider Treadmill Logo
89 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
