Question about Optimus Heating & Cooling
H-5300-bk need wiring diagram. one wire off.
I have the Optimus quartz heater , model H-5300-BK . The top two elements are always on in the # 2 position , the thermostat only works on the bottom three elements. Question ; Can I removed the top two elements , so the thermostat controls the total heater. fredh@bresnan.net
Posted on Oct 03, 2014
Need to put a hampton bay fan switch on not sure ware wires goes switch haves 3 wires L is bk 2 is bl 1 is rd from the fan theres gray brown & purple & one bk.
I don't think you have the correct switch. Most switches don't come with wires. You need a four wire capable switch. Just because the switch looks the same on the outside doesn't mean it's the same on the inside.
Sep 25, 2014 | Hampton Bay 24002 Ceiling Fan
Wiring diagram for hunter remote part 98480-02
I don't know what remote you have but try this;
Bk to Bk
Wh to Wh
Black w/wh stripe to red
Black to house black
White to house white.
fanman9952@aol.com
Sep 08, 2014 | Hunter Dryers
Wiring hunter fan model 27185 060
ceiling to receiver: BK to Bk
Wh to Wh
Fan to receiver: Bk to Bk
Blue to blue ( could be black w/ white stripe)
Wh to Wh
Green to ground
Sep 02, 2014 | Dryers
Wiring Diagram for hayman reese brake controller
Hello! Go to this link for PDF installation guide with wiring...
http://www.caravansplus.com.au/pdf/hr-5300.pdf
Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Oct 25, 2011 | Cars & Trucks
I am wiring a trailer with electric brakes. I need a diagram of my 2005 dodge dakota 7-way trailer plug, so I can figure out how to wire the trailer. Thank you.
This is for a 2003, but trailer wiring is typically standard. Only the AUX and center pin on occasion are wired for different functions:
Center: Back-up Lamps (VT/BK)
1-o'clock: Battery (RD/TN)
3-o'clock: Stop/Right Turn (BK/PK)
5-o'clock: Electric Brake (LB)
7-o'clock: Ground (BK)
9-o'clock: Stop/Left Turn (DG/RD)
11-o'clock: Running Lights (BK/OR)
Oct 05, 2010 | Dodge Dakota Cars & Trucks
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
2007 flhx.
The GY/BK wires from the 04 passing lamps plug into a two hole connector from the main harness. the GY/BK wires from that connector become one GY/BK wire that goes to the passing lamp switch. The other wire from the passing lamp switch is Yellow and is spliced in to the Yellow wire that goes to the headlamp bulb. This is not a diagram, but it is pretty simple layout. Hope this helps.
Jul 26, 2009 | 2008 Harley Davidson FLHX Street Glide
Need wiring diagram for 1984 Mercury Grand Marquis radio
94 radio
Pin Number Circuit Circuit Function 1 296 (W/P) Radio Chassis Memory Power 2 57 (BK) Ground 3 294 (W/LB) 12V Power Feed 4 19 (LB/R) Instrument Panel Dimming 5 296 (W/P) LCD Dimming (Crown Victoria/Grand Marquis Only) 6 694 (BK/LG) Ground 7 448 (O/Y) Radio On Output 8 689 (DB) Logic Mute
Feb 27, 2009 | 1984 Mercury Grand Marquis
Car raidio
speakers: L/F - OG/LG [+] LB/WH [-]
L/R - GY/LB [+] TN/YE [-[
R/R- OR/RD[+] BN/PK [-]
R/F- WH/LG [+] DG/OR [-]
WH/YE HOT f2 20 amp fuse box
BK/PK HOT VPWR
RD/BK illumination
RD/LB Hot in start f2 5 amp fuse box
BK ground
BK/LB ground
BK/OG ground
as far as I know there isn't a "remote" wire unless you are dealing with steering wheel switches
Hope this helps!!
Feb 02, 2009 | 2002 Ford Explorer
Wiring harness on my 94 Ranger
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
May 30, 2008 | Car Audio & Video
Heating & Cooling Logo
231 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
