Dg33bu pci communications controller
Need driver for pci communications controller for windows 7, pretty please. DG33BU(AAD79951-405). Thank you.
  • 3,606 Answers
SOURCE: PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Posted on Dec 27, 2007
dlundmark
  • 797 Answers
SOURCE: pci simple communication controller driver
Hello fmjos:
Go to the motherboard's maker's site and download all information needed.
You must have the drivers for that mother board, and get them usually from the one who made it.
thanks,
Posted on Sep 02, 2008
SOURCE: pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Posted on Feb 19, 2009
SOURCE: need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Posted on May 18, 2009
  • 235 Answers
SOURCE: PCI Simple communication controller driver is not
then windows 7 has no driver for the device download the latest device driver that support win 7 operating system, if there is no device driver for win 7 then you should have to wait until the manufacturer releases a driver for win 7
Posted on Nov 20, 2009
Testimonial: "Thank you"
I need the free software of Audio drivers of dg33bu,dg33fb,dg31pr calssic series for downloading
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Jun 19, 2011 | Computers & Internet
HI i install DG33bu bios update my soung is goan . please help in resting the bios version
after bios update u need latest drivers....
download the latest audio drivers from the site wer u downloaded ur bios update...
also check ur default playback device is speaker and not headphones
assuming u use windows 7
May 10, 2011 | Intel DG33BU Motherboard
No sound drivers installed in the PC..as a result no sound output... pleas help asap my motherboard is DG33BU
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 24, 2010 | Intel DG33BU G33 Express Socket 775 mATX...
There is no sound on my motherboard (Intel dg33bu)
install the sound driver from motherboard cd which is given with your motherboard.
prajwal_yes@yahoo.com
Jun 17, 2010 | Intel DG33BU G33 Express Socket 775 mATX...
Intel mother board DG33BU has a fault, how can I trace this. It had windows XP loaded, but kept shuuting, uninstalled and tried re-installing xp, freezes at set-up xp stage
OK, 2 things to check, first off the error (blue-screen) that pops up at the crash point in installation.
Second, make sure everything is connected properly, undo and reseat all drive connctions, mainly the hard drive cables to the motherboard and drive. Also, reseat the RAM.
If after checking all that it doesn't work get back to me.
P.S. if you are attempting to upgrade, try a clean install instead, it could be a registry error. Which could have been what caused the initial problem (spyware/virus).
Dec 28, 2009 | Intel DG33BU G33 Express Socket 775 mATX...
PCI Simple communication controller driver is not installed on Windows 7
Nov 16, 2009 | Intel DG33BU G33 Express Socket 775 mATX...
Computers & Internet Logo
614 people viewed this question
David Payne
David Payne
