Question about Whirlpool Washing Machines
Starter capacitor for CESET brushless motor
Washer fills and drains but drum does not spin.
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
  • 58 Answers
SOURCE: drum isn't spinning but motor is
check inner tub fastens, if they check ok, replace the transmission. note: you will need special tools to change this, if you have them great, if not, you would be better off calling a&e factory service for the repair, 18009059505.
Posted on Jun 25, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
barkencoa
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
Macmarkus
  • 2605 Answers
SOURCE: washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
Posted on May 04, 2010
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Washer will fill spin and drain but will not wash
  • first check the motor power supply whether it is fine or not
  • next check the motor coil whether it is working or not
  • If both are ok the motor power supply and coil is fine means you are suppose to check the pressure starter since it is giving the signal to the wash motor to run
  • kindly change the pressure starter to solve your problem
May 14, 2010 | Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
My washer will fill up and drain but not agitate or spin
Looks like the motor needs to be replaced. After some years of use, the motor may not have enough strength to move the drum. If you test the motor by itself, it may work, but can't handle a load.
Sep 19, 2009 | Hotpoint Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Jan 21, 2009 | Hoover AAA160 Front Load Washer
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Jan 28, 2008 | Kenmore 15864/15862 Top Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
14 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
