Question about KitchenAid Kitchen Aid Mixer Stainless Steel Bowl 5 Quart
Bad switch on kitchen aid mixer
When turning on switch feels loose and shuts off momentarily
  • KitchenAid Master
  • 1,267 Answers
Unfortunately you will probably need to split the gearcase to sort out the speed control arm.
Posted on Dec 01, 2013
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Posted on Jan 19, 2007
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
Posted on Jan 16, 2009
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
wavoconqueso
  • 57 Answers
SOURCE: when mixin bread dow the arm of the mixer moves loose
Lay the mixer on a towel and look up inside the base to the top of the neck. There's set screw up there. Tighten. If that doesn't work your shaft may be too worn and needs to be replaced.
Posted on May 08, 2009
hslincoln
  • 235 Answers
SOURCE: leaking oil from kitchen aid mixer ksm150ps
Hi, BRIANMICHELL ? How much oil are we talking about, and over what period? How old is your machine? Your KA mixer?s internal gears are factory packed with enough grease to last a lifetime, whatever that means. Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it?s been used; these factors all will eventually cause the lubricant grease to separate into its base oil from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try KSM150PS, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. For starters you may want to order parts #15, transmission gasket, and # 16, O-ring, along with some food-grade grease. Also, while you?re inside the guts of your mixer you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 01, 2009
When I switch my mixer on it goes to full speed
If it is a Kitchen Aid mixer I would suspect the little pcb with 4 wires coming out of it under the rear cover at the top.
If it is not a Kitchen Aid you will need to supply more clues.
Mar 21, 2015 | Food Mixers
Kitchen aid model kb25gixob will not turn on.any suggestions?
Put an ohmmeter across the two pins on the plug, on the mixer,,not the earth one.and turn the switch on.you should get a reading,plus it will change as you turn the switch to different settings.if no reading,suspect broken wire in plug,or mixer windings burnt out.try in a different socket
Sep 12, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Why kitchen aid mixer wont turn on
Any number of reasons such as:
Bad electric cord
Bad brush or brushes
Bad armature or stator
Control plate broken
You need the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
While this manual does not cover the Artisan specifically, the procedures do apply.
Jun 04, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid switch not working
Which switch speed or head lock? What are the problems? Need more info to help.
Sep 07, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
My kitchen aid mixer would not turn off. I pulled
you have lost the internal spring on the slide arm. a common problem but now the speed adjuster has been let go in the back of the motor. Best return to service centre as requires complete dismantle to repair, sorry.
Sep 13, 2009 | Food Mixers
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Kitchen Aid Mixer Stainless Steel Bowl 5 Quart Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
