Question about Vacuums
My magic blue vacuum has no suction. The lid seems loose and the lack of suction seems to be related to the loose lid. I cannot find a way to tighten the lid.
I have already checked for any clogs and can find none in any parts of hose etc. Thanks,
    New Friend:
    Problem Solver:
  • 12 Answers
Have u tightened the dirt cup lid.
Posted on Dec 01, 2012
galati2k
  • 281 Answers
SOURCE: bissel vacuum
take the dirt cup out and turn the bottom of it that will let you get to the filter,there should be some finger twist plates on the top,turn and take it out,there will be a foam cover around the filter,take that off and clean with warm warter,when done towel dry with paper towels,now the filter itself is water friendly ,take a brush and in up and down strokes ,clean while running water over it.above where the dirt cup goes is another filter ,just reach up inside and twist and it will come out,clean that also.now put the dirt cup back in without the filter and see if you have suction,i believe you will.let the filters dry before you put them back in then reassemble,and if that don't work, the take the hose off and see if you can blow through it .if thats not it then at the bottom on the right you will see a clear hose,thats your intake hose.there is a screw on the black fitting thats connected to it ,take it out and get you a coat hanger and bend the tip so its rounded ,thats so you don't puncture a hole in the intake hose.work the hanger down into the intake hose and push out the clog .then try it again..please leave feedback.i hope i was some help to you.iwould clean the foam filteres at least once a month
Posted on May 04, 2009
galati2k
  • 281 Answers
SOURCE: No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
Posted on May 06, 2009
  • 8404 Answers
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Posted on Dec 11, 2009
CNIII
SOURCE: I have full suction with the hose and when the
So I have exactly the opposite problem, it sucks in floor mode but the hand held has zero suction. My daughter and i just spent the last hour disassembling and diagnosing and found this: The way the suction tube is configured, you have two places to **** from, the floor and the hand held hose. If you look at the back of the machine, you can see the "y" where the two hoses join. just behind the beater bar there is a blast gate that closes when you stand the machine upright. This closes the blast gate and directs full sution to the hand hose. In floor mode as the handle tips back, a follower wheel and spring move the blast gate to open. THIS IS THE IMPORTANT PART...if the hose is not docked, there is a second place for the suction to go and you will get no suction at the floor. In my case, the center post where the spring mounts is broken and the blast gate flap does not close, so the hand hose gets no suction because it is like a straw with a hole in it, the air will seek the least resistance. In your case you either have not returned the hose to the docking port or your blast gate is stuck in the closed position. To check this remove the two screws and clamp that secure the lower hose to the suction manifold. Pull the hose stright an look inside to see if the blast gate is open or closed. Use the release pedal to cycle the machine between upright and floor mode and you should see the blast gate open and close. If you don't, well that's a whole other story. I'm off to see if I can find a replacement part at repairclinic.com. If not I will have to get some polyester epoxy and fix it myself.
Posted on Jan 16, 2010
SOURCE: Blue Moon Miele power head stops intermittantly
It is not a solid short. This is caused by static arcing in the wand and in the connectors from base to hose. I was able to fix mine by smearing some dialectric grease on all electrical parts in the wand(especially by the led switch) and in the three prong connectors at the base to hose. Have not had nay problems since doing this.
Posted on May 16, 2010
No suction of hoover carpet cleaner
Might be a bad blower/impellar - you must disassemble to check. But most likely the lid on the recovery tank is not installed correctly allowing air (suction) to leak. On most models you can remove the solution recovery tank, turn the unit on and feel for suction where the tank fits onto the base (look for the round, black rubber type seal in the front corner that mates to the round outlet on the underside of the recovery tank.) If there is good suction at this seal, then the problem is an air leak, almost always due to a loose or incorrectly fitted lid on the recovery tank. Also, if you have a detachable insert (for attachments) on the front of the recovery tank, check that the insert is installed properly. If this is reversed it will not provide suction.
Sep 02, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
I cleaned out the hose and removed brush to clean and checked belt. Everything seems to work but will not pick up or suction on carpet. The hose is totally clear from clogs. I can see the floor from one...
Hi troupdavid,
I see that your Vacuum is having issues with it suction, you mentioned that you took it a part to clean it, see steps below.
  • Check if everything is inserted properly and is in place.
  • make sure the the Vacuum airflow does not have anywhere else to come out from, cause if there is, the vacuum suction will really not be really getting enough suction to be able to get dirt Off the floor.
  • Make sure the bag is correctly placed in the Vacuum and is tucked in properly for proper suction.
  • The hose should be twisted to be locked into Place, either clock wise or counter clockwise which ever makes it lock to the hose socket.
  • Also check the agitator shield beneath making sure that the Belt is not pinched in or squished by the Agitator and the Agitator shield, this can also cause lack of suction for the Vacuum.
I hope that this will be of help regarding your query.
Have a nice day,
mvincentc
May 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
My Craftsman wet/dry vac is not picking anything up. It seems have some suction...not as much as it used to. I just replaced the filter and that did not help. Any suggestions?
disconnect hose and check suction at vacuum port. if suction is poor ther turn off, lift lid, e stick coat hanger wire in port from the backside diverter. also, clean filter.
May 16, 2010 | Vacuums
Not picking up in tank
There are a few things to check. First make sure the front panel is installed (the square part that is removed for using the hose). Next make sure the lid has snapped in place. Next, remove the lower tank and look for the round tube for a rubber seal, should be on. I have found these to be the most common problems relating to your suction issue. Also verify that it actuallu is putting water down ( this is another issue).
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
It wont pick up with a new bag in and it seems to **** back in
Check if there is something stuck in the the suction tube, telescopic wand or in any of the parts involved. I had the same problem due to a number of chocolate wrappers stuck in the wand. I almost went and bought another one, luckily i had the sense to ask the salesman at sears the same question and he put me on the right path. The suction tube and wand are detachable from the unit, so you should be able to unplug the parts and check. This is the same solution if you motor is running fine but you have lost suction and\or bag shows full when it is not. Hope i am saving someone some money by stating the obvious here, just the way the sears salesman helped me.
Nov 07, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Lack of suction on the main part of the vacuum
There are two easy things to consider if you have a lack of suction on the vacuum:
1. Replace the bag and check the hose leading to the bag to see that it's not blocked.
2. Replace the belt.
You may think that the belt doesn't have anything to do with suction, but it does. When belts are worn and stretched, they don't work efficiently.
Jul 07, 2009 | Kenmore Vacuums
My Miele vacuum full bag indicator
Check the suction at the vac, without the hose, if it is strong, then you hose is clogged. If it is weak, filters could be the problem, one is the back where the bag sits, the other is on the top, you can see it when you raise the lid.
Dec 07, 2007 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
