Question about Kenmore Dryers
Dryer shuts off after 10 minutes of running what is causing this
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 01, 2012
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 61 Answers
SOURCE: dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
Posted on May 06, 2009
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
Our 4 cycle whirlpool dryer runs for 5 -10 minutes gets hot and shuts off.
check to see if the dryer vent is clogged up - When a dryer gets to hot it will shut off to prevent catching fire!!! If the vent is clogged it forces the heat from the dryer to stay in and that causes the dryer to over heat!!!
Jun 25, 2011 | Dryers
Kenmore Elite Dryer 63942 Push on button, turn the timer to 30 minutes.Within 10 minutes the dryer shuts off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2010 | Kenmore 63942 Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
