Question about Dell 924 All-in-One InkJet Printer
I replaced both b/w and colour cartridges. Now my 926 printer displays 1203 error. I can not find my manual and can't fix th problem. HRLP please. UI need to get an asignment in today. Ta, Wendy
    Problem Solver:
  • 17 Answers
You can download a manual here:
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
Posted on Jan 11, 2009
  • Deceased Jan 11, 2009
    I found some more information for you.
    Error code 1203 means that you have a print head short error. The way to fix this is to:
    1) Clean the contacts on the cartridge w/ a damp cloth. Only do it in one direction so that you're not smearing ink all over the contacts!
    2) Disconnect and then reconnect the power cord from the wall and from the back of the printer. Wait about 30 seconds, and then plug everything back in.
    If this doesn't work, you may need to replace the ink cartridges...you can always try it one more time just to be sure
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
I am getting a 1203 error code for my dell 926 aio printer. I have tried discontinuing power and restarting it and I have tried reinstalling the ink cartridges. Now what?
You can only try it could work
or
Jan 11, 2010 | Dell 926 All-In-One InkJet Printer
Dell 926.... the printer will not acknowledge that a new cartridge has been put in. It will not work. previously had the error code 1203, a short circuit in print head. That has now disappeared. Help...
or
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aug 10, 2009 | Dell 926 All-In-One InkJet Printer
After installing new color cartridge got error 1203-print head short. Followed manual's instructions to repair but problem still exists.
or
Jul 08, 2009 | Dell 926 All-In-One InkJet Printer
Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
May 18, 2009 | Lexmark C533DN InkJet Printer
Displays Error Code 1203 - What is that? User Manual is lost.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
DELL AIO 926 PRINTER
Hello there try doing this.
or
Apr 15, 2009 | Dell 926 All-In-One InkJet Printer
It says error 1203 consult user manual...
Insert a different ink cartridge. I had the same problem, and it fixed it right away.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
91 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
