Connecting android tablet to wifi
I purchased a Polaroid 7" tablet and when I try to connect it to my wireless network it says authentication failed. How do I get it to connect?
  • 32,281 Answers
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Posted on Dec 01, 2012
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
oldnovii
  • 667 Answers
SOURCE: wireless secured network key code
Hi BabyDoll - to find your key, log in to your router. Enter 192.168.0.1 into your browser. If the defaults haven't been changed, the user is " admin" all small case without the quotes. There is no password. Just enter the user and leave the password blank. To get the key, click on the wireless button on the left. Then look down the page and you'll see the passcode fields. This is what you're looking for. Also take notice of what's above it such as WPA, WEP, etc. Write this info down. You can also go into your pcs that you use wireless on and put that key in and the kind of security (WPA, etc) so that it will not ask for it every time.
If this solves your problem PLEASE rate this as fixed. If not, DON'T RATE YET. Let me know what happened and I'll be happy to assist you further. If you need to know how to enter the info so that you won't have to enter it all the time let me know. I'll help you with that. Let me know what happens. Thanks.
Jeff
Posted on May 22, 2008
redhaze89
  • 854 Answers
SOURCE: I have new Sony Vaio
Possible reason why your computer is not getting online wirelessly is because the wireless settings on the router and the wireless settings on your computer do not match. Here are some troubleshooting steps that I suggest you try:
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Posted on Jul 08, 2009
postscript
  • 48 Answers
SOURCE: Computer connects to wireless router, but doesn't authenticate
what is the operating system of the computer? add the network manually in the Preferred Networks then restart the computer.
Posted on Sep 16, 2009
byteguy
  • 2229 Answers
SOURCE: I have a problem with my router login.I have tried
If the router ssid reads virginmedia.... then you have not reset the router. The default name for a Netgear router is Netgear.
Push the reset button in (on the back of the router) and hold it for at least 15 seconds or until the power light flashes.
Now the username and password and SSID should be reset to the default.
Posted on Oct 23, 2011
How do I get it to stay connected to my wireless internet?
Resolving Internet connection problems - Belkin
www.belkin.com/us/support-article?articleNum=10823
BelkinFrom wireless home networking and entertainment, to mobile accessories, energy management, and an extensive range of cables. ... Sign In · Cart0 items; Free Ground Shipping on Orders through December - Details ... How do I find my model number?... Stay tuned for exclusive offers, exciting new products and more.
My android tablet won`t stay connected to wifi network ...
www.askmefast.com > ... > Wifi
My pc tablet wont stay connected to wifi internet help ... read more ... Someone said: i have a belkin router i have just put a security setting on it all the pcs work fine put in the password but my android ..... Ok it is a slow signal using other network .... Irulutablet doesnt work unless i m in the same room with the wireless router.
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Jan 05, 2016 | Irulu 9 inch Android Tablet PC, 4.2.2...
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
How do I connect to my wifi
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
Cheers
Nov 17, 2014 | Polaroid 7" Internet Tablet Android 4.0...
Why won't my tablet connect to my wifi ....
Once you identify your wireless network (SSID) you must put in a "password" or network key.
Jun 19, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
I cant get my polaroid 7" tablet powered by android 4.1 to get to my wifi . the wifi on the tablet is turned on .i have put in the password but keep getting authentication problem. please help
Maybe try going to the router settings and changing the security settings. See if turning off wifi password solves the problem then turn it back on.
Oct 19, 2013 | Polaroid 7 in. Internet Tablet
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
10.1 polaroid tablet 4.0 won't connect to internet
If the tablet is running Android ICS and you use secure your wireless network this is the issue. It's a bug in ICS. You will have to disable your security. You maybe able to use WEP security and get it to work.
Dec 26, 2012 | Polaroid PRMDVD0010S 4x 8CM 1.4 GB/30...
Authentication problem when trying to connect to wifi
This tablet is running Android ICS. If the wireless you are connecting to is using WPA or WPA2 security you will need to set it to WEP or none for your tablet to work. This is known bug.
Dec 05, 2012 | Visual Land Connect 7" Tablet
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
