Question about Hardware & Accessories
Instruction s #0144082
Utilitech outdoor 1-outlet timer
heatman101
  • 43501 Answers
SOURCE: I have a UTILITECH 1-
Yes you press down the bars for the length of time you want it on....
heatman101
Posted on Sep 17, 2010
SOURCE: Utilitech 1 outlet timer tm01dhbl how do i program
Just bought 2 of these things. I can't figure out how to set "on" either, and I have called Utilitech twice (left messages) and left an e-mail. So far, no answers. Let me know if you find a solution, or they go back to the store.l
Posted on Nov 03, 2010
SOURCE: how to program utilitech 1
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Posted on Dec 02, 2010
SOURCE: I bought a utilitech three
I bought one also but am taking it back today as I am not satisfied with the performance and the internal battery dies losing all programming. The instructions below are word for word from the manual but not all that clear. Since I can't post the diagram from http://www.thencc.com/westinghouse/LS/Instruction/T28499_TimerManual.pdf (if I can post links here), I substituted words in the "Set Mode" section instead. This is for the Utilitech 0149289 model and also applies to the Westinghouse and Stanley equals. Good luck.
3-Outlet Photocell
HEAVY DUTY OUTDOOR TIMER
Tri-Mode Digital Timer
3-Wire Grounded Outlet and Plug
6 in (15cm) AWG 14/3 SJT vinyl cord
Rated: 125V/15A/1875W Tungsten
60Hz
INITIAL USE:
Before initial use, please plug in your timer for at least 1 hour to charge the internal battery. After the LCD display appears, your unit will be ready for programming.
RESET:
Press the "+" and "-" buttons at the same time to reset your timer. This will clear all programmed settings.
SET CURRENT TIME:
Press and hold the "TIME" button to enter the current time. First, set the day of the week: press "+" or "-" button to set today's day.
Press the "TIME" button to enter the hour setting. Press the "+" or "-" buttons to set the current hour. Be sure that AM or PM appears correctly.
Press the "TIME" button to enter the minute setting, Press the "+" or "-" buttons to set the current minute.
Press the "TIME" button to finish setting the current time and return to normal display.
SET MODE:
Press & hold the "MODE" button to scroll between the different Mode settings:
Display Mode Explanation
Digital Timer On/Off at your exact
programmed times (Picture of clock inserted here)
Photocell Countdown Timer On at Dusk or On immediately,
Off after 1-12 hours (Picture of what looks like half sun on horizon)
Digital Timer + Photocell On at Dusk, Off at your exact
programmed times (Combined picture of clock and half sun on horizon)
SET PROGRAM:
After choosing your mode, set the timer program by holding the "PROG" button for 3 seconds, and then follow the appropriate section below.
SET PROGRAM: DIGITAL TIMER
The first setting is "PROG 1 ON" which should appear on the screen. Set the desired day of the week setting for your timer using the "+" or "-" button to scroll between choices. You can select each day individually, Monday to Friday, Saturday/Sunday, or the entire week. To have your timer turn On/Off at the same times every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press "MANU" to enter the "PROG 1 ON" hour setting. Press the "+" or "-" to choose the desired hour for your timer to turn ON. Be sure to cycle through until AM or PM appears correctly.
Press "MANU" to enter the "PROG 1 ON" minute setting. Press the "+" or "-" to choose the desired minute for your timer to go on.
Press the "PROG" button to enter the "PROG 1 OFF" setting. Repeat steps 2 & 3 to set your desired Off time.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and is ready for use.
SET PROGRAM: PHOTOCELL COUNTDOWN TIMER
The first setting is "PROG 1 ON". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until
Press "MANU" to enter the hour setting. Press the "+" or "-" to set:
Display Explanation
d Dusk to Dawn - On at sundown, Off at sunrise
d:01 to d:12 On at Dusk, Off 1 to 12 hours later
S:01 to S:12 On immediately, Off 1 to 12 hours later
SET PROGRAM: DIGITAL TIMER + PHOTOCELL
The first setting is "PROG 1 OFF". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press the "MANU" button to enter the "OFF" time hour setting. Press the "+" or "-" to set. Be sure to cycle through until AM or PM appears correctly.
Press the "MANU" button to enter the "OFF" time minute setting. Press the "+" or "-" to set.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and be ready for use.
MANUAL OVERRIDE:
Press the "MANU" button to choose the timer status:
Display Explanation
ON Continuously ON
OFF Continuously OFF
AUTO Timer will turn On/Off according to program settings
Posted on Dec 08, 2010
SOURCE: need instruction to set a
It seems there is more than 1 Utilitec 014289 outdoor timer.
Each has same buttons, but different words under each button.
One has 'week-hour-min' on top row.
Other has 'manu-mode-prog' on top row
Manuals for both types appear on link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Manuals contain more useful information and illustrations than I can type in an answer and the manuals seem straightforward. If you need help with specific programming steps, add a comment with identification which manual applies to your timer. I will be glad to help for free.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Posted on Dec 23, 2010
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
Outdoor 3-Outlet Photocell Timer
Photocell is 'seeing' lights and thinks it's dawn so it turns off.
When lights are off, timer thinks it's night and clicks back on.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
1) Turn photoeye away from lights.
2) Buy new timer since photoeye is first thing to malfunction on cheap Christmas timers.
3) Buy new timer at Lowes, and return defect in new package
Dec 02, 2012 | Hardware & Accessories
I have the Utilitech #015550 outdoor 2 outlet timer. Can't find the instructions. Can you help? Thanks
May 2011: Utilitec 015550 is not enough information to identify timer at this point.
New timers come on the market.
Do one of the following to find best answer
1) Add a comment and describe timer in detail.
2) Add a comment with in-focus photo of timer posted on Flickr.
3) Open following links to identify same-similar timer, and add a comment if needed:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Hardware & Accessories
Need instruction to set a utilitech outdoor 3-outlet photocel timer #0149289
Dec 22, 2010 | Hardware & Accessories
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
Hardware & Accessories Logo
138 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
