Question about Quasar VV-2002 20 in. TV/VCR Combo
Picture shadow I have a 52" Quasar TV that has a red shadow on the images shown. I have gone into the SET UP menu, and tried adjusting the "convergence" option with little or no effect. I was told this was the normal manner to fix this problem, but this solution isn't working for me or perhaps I'm missing something here.
    President:
  • 3,130 Answers
No I am afraid you have the typical convergence problem. if you tried the adjustment, and it did not work, there are two convergence amp IC's that need to be replaced. they are on the printed circuit board, and they stand up mounted to a large metal heatsink. The IC's are black, and have white lettering on them, and statrt with STK. They will need to be unsoldered. If you have the soldering knowhow, this should not be so bad for you to do. But if you do not, play it safe and have a tech come in and replace these convergence amp IC's. Good Luck
Posted on Jun 07, 2007
Sony Bravia 52 blurry Picture
Contact the authorized service center for Sony. So many adjustments have to be done after T'Con boar replacement. You can do it, if you are an expert engineer specialized in electronic engineering. If not, please do not make the set irreparable by doing more adjustments that you do not know. OK?
Aug 30, 2012 | Sony Kdl-52vl150 52" HDTV LCD TV
Bowed red green lines at top screen. picture looks like it in 3d.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
THE PICTURE ON MY TV IS SHOWING A YELLOW SHADOW ON ON SIDE MORE & A BLUE SHADOW ON THE OTHER. IS THIS A BULB PROBLEM?
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2011 | Panasonic PT-47WX49 47" Rear Projection...
The red in the picture is shadowing the rest of the picture giving it a 3d effect
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture has a red shadow and no sound
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
Please do us a favor and rate this solution after reading
Aug 02, 2010 | RCA D52W19 52" Rear Projection Television
Red shadow on tv
If this is a projection tv a shadow usually indicates bad convergence. If you cannot adjust convergence from customer menu have a professional replace convergence amplifiers and reconverge
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture is mostly red
might try to grayscale but that usually means taking the back off and making the adjustments
Oct 30, 2007 | Quasar SP-3233 TV
Red shadows in picture
Possible "blooming"==red CRT, adjust screen control==qualified tech only.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
Quasar VV-2002 20 in. TV/VCR Combo Logo
41 people viewed this question
Top Quasar Televison & Video Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
