Question about Kitchen Ranges
Ge gemini range gas smell
The gas co. came out and said that I have a slight gas smell near the oven. Before I call in a repair, does anyone have any suggestions?
  • Tricia Menture
    Tricia Menture Dec 01, 2012
    MGT8885XS 30
  • Richard Roth
    Richard Roth Dec 02, 2012
    That model number comes up as a washing machine.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • Tricia Menture
    Tricia Menture Dec 02, 2012
    Model: MER6765BAS. I had to find it online. I dont know how to find it on the stove. On my old warranty paperwork it also says model/serial: 28 esp4-gas so i don't know if that helps.
  • 4 Answers
SOURCE: GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Posted on May 18, 2007
aborcass
  • 2651 Answers
SOURCE: ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Posted on Feb 28, 2008
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
I have a Maytag Gemini double oven and the right rear burner ignites but wont shut off?
Great move, you kept your domicile from exploding. It sounds like a bad valve but I am only guesing.
Nov 27, 2014 | Maytag Gemini 30" Self-Cleaning...
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom oven wont heat. No gas smell.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 16, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gexl44 gas range, oven stopped working for no apparent reason, stovetop still works just fine, no gas smell
Oven not Working or
Oven not Heating
heatman101
Feb 04, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Our gemini stove's bottom oven will not ignite
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Oven not Working or Oven not Heating
heatman101
Sep 13, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
MY GE PROFILE RANGE OVEN DOOR POPS OPEN WHEN THE OVEN LIGHTS AND IT HAS A SLIGHT GAS SMELL
I have the same problem and GE has a technical memo out on this. It requires a programming change. Right now, I am trying to get GE to fix it at no charge, but so far, no luck.
Aug 21, 2010 | GE Profile JGS968 Gas Kitchen Range
Oven not heating up to temp. Sometimes get small explosion inside when starting. Sometimes small slight gas when lighting. Top burners work fine. Model GE JGBP26GEJAWH
heatman101
gk
Aug 13, 2009 | GE JGBP26 Gas Kitchen Range
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
