Question about Roper RES7646KQ Electric Dryer
Had thermostates checked and still no heat
I had thermostats checked and heating element also. Dealer said all was good. Still no heat. Now what?????
    Scholar:
  • 58 Answers
How does the dealer know if they are good? Did he come to your home to check it? and if so why did he not check for power to the element? If your heater and t-stats are good the only thing that will prevent your heater from operating is the centrifugal switch on the motor. that's provided your t-stats and heater are in fact good. And you have the full 220 volts suppy to the dryer. Keep in mind the heating element is the only thing that's runs on 220 if you only have 120 powering the unit your timer and motor will still run. you can check the power by removing the plug cover on the dryer, you will have a red,white,and black wires from white to black you will read 120, from white to red you will read 120 and from red to black you will read 220 if you don't read 220 between black and red or 120 from red or black to white you have a power issue and nothing wrong with the dryer. Good luck hope this helps you
Posted on Jan 11, 2009
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
I have a Kenmore Dryer mod. 96281100 which runs but no heat. I tested power input at 240v, thernal fuse closed, thermal hi temp closed, element closed and not grounding, thermostat cut-off closed, and...
If you have 240 VAC across the element, but the element is not heating, then you have a bad element. If you don't have 240 VAC at the element, then work your way back with the voltmeter to find where the voltage is dropping
Nov 11, 2009 | Kenmore Dryers
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
No heat
solutions are
blown fuse takes 2 (30 amp fuses to allow a dryer to heat )
element broken
thermostates defective eather limits or cycling thermostats
moter switch defective or plugged with lint not allowing the switch to close when it starts
timer not asking for heat
no signal to timer from temp selector witch
(solv ys prob)
Oct 17, 2009 | Maytag Dryers
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Kenmore 68702 electric dryer heat doesnt shut off
If the dryer completes the cycle bit does not shut off, then you have to replace the timer control assembly.
If instead the dryer hangs at the middle of the cycle and does not advance, check the thermostate.
If the dryer does not heath and does not advance, then check the heating element, the thermostat and the fan.
Mar 06, 2009 | Kenmore Dryers
Dryer not heating hoover 5030d
Some dryers have a thermo-fuse. It doesn't look like a normal fuse. It can look lide another thermost or a long plastic device with two wires foing to it. Also they have a high limit thermost that can open. There is a switch on the motor that won't let power go to the heater until the motor reaches a certain RPM. If this is a 220 volt dryer, it could also be the house circuit breaker. If one half of the breaker is bad or tripped, the motor can still run but you will have no heat. If the dryer has a heat selector switch IE delicate, no heat, or high heat. You should check that for continuity when in one of the heat selection positions. The timer can also cause no heat. Check the timer contacts when it set in a dry cycle. Hope this helps.
Nov 20, 2008 | Dryers
No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Dec 29, 2006 | Hotpoint TDC32 Electric Dryer
Roper RES7646KQ Electric Dryer Logo
85 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
