Question about Ricoh A3 Gel GX7000 InkJet Printer
How to reset ink levels on a ricoh gx7000 - Ricoh A3 Gel GX7000 InkJet Printer
4 Suggested Answers
SOURCE: I just purchased the Ricoh
I would call your vendor. Or if you bought the sawgrass technologies ink, give tech support a call and have them help you download the necessary ICC profile for your printer. Often they can walk you through setup. You will need to delete the current one you son installed.
Narri
Posted on Nov 09, 2010
mariolands
  • 2296 Answers
SOURCE: Ricoh Gx7000 inkjet A3 Printer - what does 'error
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Posted on Feb 13, 2011
SOURCE: how do i reset the
Push the menu key.
Push enter key three times.
Turn printer off then on
See my video at www.condetv.com
Search for waste ink.
Posted on Mar 13, 2011
I have error 997
CHECK THE INK CARRIAGE IS MOVING ACROSS TO HOME POSITION. THIS CAN BE CAUSED BY THE INK CLEANING PROCESS NOT LOWERING THE LOWER TANK PROPERLY. IF YOU REMOVE THE RIGHT HAND COVER YOU WILL SEE THE CLEANING UNIT. THERE IS A WHITE SHAFT WITH A CROSS HEAD SLOT YOU CAN TURN TO LOWER IT AND THEN REBOOT THE PRINTER WITH LUCK IT WILL GET RID OF THE CODE. HOPE THIS HELPS. ANDY When the carriage moved to the right, the carriage did not stop at the HP. Or, the carriage scan check failed. • Horizontal encoder sensor loose, broken, or defective.
• Horizontal encoder film broken, disconnected, or installed upside down.
• HRB defective
Mar 11, 2015 | Ricoh A3 Gel GX7000 InkJet Printer
Ricoh gx7000 error code 993
This signal is triggered by the HVPS due to an accumulation of
condensation or ink spillage onto the transport belt.
?? Clean the transport belt.
Feb 28, 2014 | Ricoh Corp Aficio GX7000 GelSprinter Print...
I have a ricoh gx 7000 used for sublimation. Everytime I turn it on, I get a "paper misfeed" message. HELP!!
Dear .
Paper miss feed error indicates to :
1- Piece of paper inside duplexer unit check out from the back side..
2- magnetic strip (encoding tape on the top of linear steel bar) is dirty or it has some ink spots
use alcohol & cotton pass along the strip from the 2 side.
Note turn your machine off and un-plug the power
To clean behinde the head area you should first turn the machine on, when the head move to the left side unplug the power cable
I hope it may help
Yasir Risay
Aug 20, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
How do i reset the counter when i have replaced a ink collector unit on my richo gx7000.
Push the menu key.
Mar 13, 2011 | Ricoh Aficio GX3050 GelSprinter
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
I just purchased the Ricoh GX7000 for sublimation. Unfortunately, my son set up the printer and did not realize the inks that come with it are not to be installed. He did. I have not printed anything, but...
Narri
Nov 04, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
I have a Ricoh GX7000 Gel printer. I have diagnosed that the main board is faulty. How can I get a replacement circuit board for my printer... anyone with any useful info?
If it's the entire board I don't really know. You might be better off getting a new printer If it's a chip you might try here...Good luck
http://www.aliexpress.com/wholesale/wholesale-ricoh-oem.html
Oct 18, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Power Outage
Unfort don't have a solution but curious as to the ink you were using. Were you using OEM inks or dye sublimation ink from like Sawgrass ?
Jul 27, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ricoh A3 Gel GX7000 InkJet Printer Logo
83 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
