Question about Aprilaire 400 Humidifier
Keep blowing 24V transformers
I believe I wired this correctly according to Aprilaire's "New and Improved Wiring Diagram" that came with the product. The humidifier cuts in properly when the furnace goes on calling for heat, but the solenoid did not open to let water flow and I blew out the 24V transformer. I got a new one and first wired it directly to the solenoid and the water flowed properly. The instructions for the unit says to wire the yellow wires from the solenoid along with the white wires from the float switches. When I first did that the float switches seemed to work in reverse of what they were supposed to do, i.e the solenoid did not open unless I lifted the floats. When they were in their normal down position the solenoid did not open. In addition, after a few minutes of running that way I blew out my second transformer. I had one wire from the transformer wired directly to one of the H terminals on the ADHC. The second wire went to one set of yellow and white wires from the solenoid and the float switches. The other set of white and yellow wires were wired to the second H terminal. That sure seems to be what their wiring diagram calls for. Why is this not working properly and why am I blowing transformers?
    Top Expert:
  • 12,962 Answers
Somewhere in the mess you have described there is a short that is compelling the transformer to put out more current than what it is designed for. It gets hot, really overheats, insulation melts, and the wires melt. Ergo blown transformer.Problem is with whatever that unit is plugged into/powering..
Posted on Mar 03, 2017
2 Suggested Answers
  • 3 Answers
SOURCE: Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Posted on Dec 28, 2007
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
I have an AprilAire 550A with bad humidistat. Can't find replacement. Got a 550 but wiring not right. Not sure what to do!
I believe they just updated model number descriptions. The basic design of that humidifier hasn't changed much over the years. I would go to their website and look for the one that is simiar to your model and get the humidistat for it. They are pretty basic devices as far as what the humidistats do. 24v power and common
Feb 23, 2013 | Aprilaire Humidifiers
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
Dec 14, 2012 | Aprilaire 400 Humidifier
No "C" on furnace power strip for humidifier power "C"
Hello, since this humidifier has a transformer installed with it, you bring one wire from humidifier to Humidistat and then a wire from humidistat to Transformer. You will need a current sensing relay to turn the humidifier on and off with the Furnace cycle. I will attach a link for a wiring diagram for your Humidifier http://docs.electronicaircleaners.com/aprilaire_700a_installation.pdf
Nov 15, 2012 | Aprilaire 700 Humidifier
Does anyone know where i can find a wiring diagram for a model 600 aprilaire humidifier.
I hope this helps.
http://www.aprilairepartners.com/products/category/humidifiers
Scroll down towards bottom of page. I looked under the heading "CURRENT RESIDENTIAL MANUALS", and clicked on "Humidifier Model 600 Series Safety and Installation Instructions Template with Model 60".
Dec 19, 2010 | Aprilaire 600 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
I need a wiring diagram
www.ntsupply.com/files/products/56_install.pdf
Oct 19, 2009 | Aprilaire 550 Humidifier
Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
http://www.arnoldservice.com/Aprilaire_700_repair_parts_supplies.htm
Dec 07, 2008 | Aprilaire 700 Humidifier
Aprilaire 400 Humidifier Logo
353 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
