Question about Dayton Electric Heater
Dayton electric heater thermostat issues? - Dayton Electric Heater
5 Suggested Answers
  • 8 Answers
SOURCE: dayton electric garage heater
need to check you fan wires, some have differant colors on the moter for the differant speeds, you may need to change the fan speed by unplugging one of the wires and replacing it with another. hopefully you still have the manuel , check with it first!!!
Posted on Jan 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I've got a Dayton 3E369 Unit heater. The electric
Sounds like it has a bad fan switch wich is no more than a small circular bi-metal switch that expands when heated closing a switch. Get a parts breakdown off the net. I am sure you could find the switch in your area and replace it yourself.
Posted on Oct 21, 2009
  • 58 Answers
SOURCE: dayton g73 electric heater less than two months
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Posted on Jan 27, 2010
  • 381 Answers
SOURCE: Just bought a Dayton electric heater to heat a 12'
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Posted on Dec 28, 2010
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Thermostat for dayton hot water heater
On the electric, generally there is an upper & lower thermostat... On a gas, it is built in to the gas valve.
Dec 16, 2013 | Dayton Water Heaters
I NEED TO REPLACE THE THERMOSTAT WHERE IS THE
Dayton is a product of Grainger Industrial Supply. Here is a link to their website. You can order parts online or search for the location nearest you.
http://www.grainger.com/Grainger/wwg/start.shtml
Mar 19, 2011 | Dayton (3UG73) Electric Utility Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
Mack B
Dec 28, 2010 | Dayton Electric Heater
I need a temp setting switch for my 2 mounth old electric garage heater. Where can I buy one?
The thermostat must have cost 2 cents. I replaced it with one from electric baseboard, real nice piece. Dayton should do the same.
Feb 03, 2010 | Dayton Heating & Cooling
Dayton g73 electric heater less than two months old and thermostat goes out any ideas
Jan 26, 2010 | Dayton G73 Utility Heater
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Use Breaker for Switch?
Thats ok, but i would put a thermostat switch on it also !
Nov 17, 2008 | Dayton Electric Heater
Dayton 2yu62 doesn't work at all
Need to check heating elements and replace if necessary. If your checks are complete that is the answer I think.I suggest reviewing your findings. The heating elements rarely go bad.
Oct 22, 2008 | Dayton Electric Heater
Dayton Electric Heater Logo
22 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
