Question about Canon PIXMA MX700 Office All-On-One Inkjet Printer
Pixma mx700 fax status says standby after it transmitted
I sent a fax and while it was sending it said transmitting but now it says fax status Standby....what does this mean. Did the received get the fax?
4 Suggested Answers
  • 77 Answers
SOURCE: Sending and receiving problems
Where the telephone line comes in from the wall, make sure that it is plugged in the "line" or "wall" port. There is probably another port call "tel" or "acc". If the line is plugged into that port you will still get a dial tone but you are not connected to the fax's modem. You hope that's it. Ed
Posted on May 17, 2007
  • 59 Answers
SOURCE: Canon CFX-L4000
The correct solution was posted. Make sure the phone is plugged into L not the telephone or handset symbol.
Posted on Aug 09, 2007
Logjam
  • 159 Answers
SOURCE: Canon Laser Class 8500 plain paper facsimile
Thats the BJC 8500 not the LC 8500
Posted on Feb 29, 2008
What does the message 'stand by' mean after faxing a document with the pixma mx712?
when data is sent by fax the processes are
the fax machine calls the receiving fax
The receiver is established with a secure line
the data is transmitted
the receiver fax prints out and verifies that the transmission was not corrupted ( stand by)
then returns an OK message and a transmission date
Feb 13, 2018 | The Office Equipment & Supplies
How to confirm message sent what is the code so i know the party is sent it to received it
There is a transmit report which can be auto printed for every fax message sent out. Go to menu, under the fax sub-menu, turn on the transmit report (under report).
Apr 10, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
Fax line picks up during phone call
Most faxes have a small adapter plugged into the back of them and then the phone line plugged into the adapter and what this adapter does is eliminate 2 of the contact wires in the main phone line. Faxes only use 2 of the transmit wires. This probably will eliminate the interrupt. The adapter can be picked up at stores such as Radio Shack
Sep 15, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
I have a Canon MX700. I tried to send a fax then
Try removing the ink and printhead, turn printer off and then on. If printer asks you for the printhead, then ink, then you may have just gotten a working printer again. I hope this works.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 05, 2017 | Canon PIXMA MX700 All-In-One InkJet...
I can't seem to get the communications connections connected to send a fax. I have internet telephone and internet service and don't know where to connect what?
FAXes are sent and received through the telephone line connection on the back of the printer. There are two RJ11 connectors - one to your house wiring, and the other to your telephone handset. At a minimum, connect to your house wiring.
The FAX drivers and software should have been installed with the rest of the software. Confirm by checking in Control Panel, Printers, to see if "Canon MX700 series FAX" is in the list.
I use Vonage as my telephone service provider, and I've had excellent results both sending and receiving.
Hope it helps!
Mike
Dec 12, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Fax question
You want a TX (transmit) Report. You can have the report printed after each fax is transmitted, including the first page of the fax sent if desired. Follow these steps to turn on the report.
1. Press Menu button
2. Use (left or right) arrows to FAX SETTINGS, press Set button
3. Use arrows to REPORT SETTINGS, press Set button
4. Use arrows to TX REPORT (may be there already), press Set button
5. Use arrows to OUTPUT YES, press Set button
6. If screen says REPORT WITH TX IMAGE, press Set button
7. Use arrows to ON or OFF, as desired, press Set button
8. Press Stop/Reset to exit the menu
May 05, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Jounal Entry Dates
Most machines will only keep a certain amount of transactions in memory. Your fax that you are looking for is probably over the amount of transmissions kept in memory. One suggestion, if the fax was a long distance number, you could check your phone for that number. You also might want to set your machine to print a confirmation report for every fax sent and staple it to your fax for further reference.
Jun 25, 2007 | Muratec F320 Plain Paper LED Fax
Canon PIXMA MX700 Office All-On-One Inkjet Printer Logo
147 people viewed this question
old marine
old marine
