Question about Toshiba Satellite L675DS7040 AMD Athlon II DC P340 22GHz4GB320GBDVD SMLFbgnWC173" HD+W7HP6 PC Notebook
Toshiba MK 3265GSXN failure
Windows detected a hard disk problem, the following hard disks are reporting failure
SOURCE: toshiba a105 recovery disks display
if you already formatted the hard drive;there's n o way for you to get restore image of mce 2005;you have to call the toshiba tech and send your har drive to load the restore image again.u can also try to tap 0 while rebooting your machine.to access the restore image if u still have it instead of using the recovery disc.
Posted on Oct 15, 2007
SOURCE: hard disk help
Hi
I have Satellite A205-S5804
Im try to download wendows xp to my lap top
Iwas do it successful
But I cant find any driver for my lap top
Like vga –Ethernet- sound-display-wireless
Plz can u help me
Posted on Mar 15, 2008
mspcrepair
  • 169 Answers
SOURCE: Replace hard drive
You didn't ask any question ....but you already know the answer. The drive is most likely now a paperweight.
If you have critical data to recover, you can contact Drive Savers ...they're pricey, but they're good!
Hope this helps - remember to rate! :)
Posted on Oct 02, 2008
Report
  • 50 Answers
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
Basilio00920
  • 155 Answers
SOURCE: toshiba a200/205 series Hard disk is toshiba mk1246gsx need compatible driver for windows xp I need to convert my OS from vista to XP
Well... this is common on newer laptops. It is due to the fact your HDD is SATA (Serial ATA) and Windows XP CD does not have the drivers needed to recognize it. The solution I use is a bit High Tech: to remaster your Windows XP CD including the drivers needed. Or, just settle to live with Vista until January, when Windows 7 will be available to the public. If you are not faint of heart, google this: nLite; with this program you can remaster your XP CD. (You need a working PC with CD-RW to actually do the job).
Posted on Apr 14, 2009
WINDOWS DETECTED A HARD DISK PROBLEM Backup your data to prevent information loss, then contact the computer manufacturer if you need to repair or replace the disk
It is predictive failure. Start backing up your files and replace drive. You can also run chkdsk c: /f/r to fix errors on the drive from the command prompt. C being the drive letter or whatever your is.
Feb 27, 2013 | Toshiba satellite c660
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
PXE-61 Media test failure/ PXE-MOF Exiting PXE Rom
The possibility of the hard disk is not detected. So, when the laptop is powered on, the hard disk is not detected.
solution
Remove the hard disk, then reinsert
Nov 22, 2011 | Toshiba Satellite Computers & Internet
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
MY HARD DISK HAS EXPERIENCED A PROBLEM I CANT INSTALL THE OPERATING SYSTEM. I GET AN ERROR SAYING DISK FAILURE AND ITS DOWN NOW I CANT DO ANYTHING
Disk failure = the hard disk has a hardware failure = it's dead. It can't be fixed, replace it and reinstall.
Apr 15, 2010 | Toshiba Tecra A3 Notebook
Warning Message that windows Dectected Hard Disk Problem
Go and see a technician immediately. Your HDD seems to be on the verge of failure.
Apr 01, 2010 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
SMART failure predicted on Hard disk 2: toshiba mk1637gsx
back it up immediately, the software on the HD has detected something failing, and it is telling you it is time to back up that drive, and replace the drive, these reports, are usually 100% right.
Feb 17, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Toshiba Satellite L675DS7040 AMD Athlon II DC P340 22GHz4GB320GBDVD SMLFbgnWC173" HD+W7HP6 PC Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
