Projector help we unplugged the power cord and can not get it to turn back on
  • rcallihan Jan 13, 2009
    InFocus IN2102 I have tried multiple plugs. sometimes it turns on, somtimes it doesn't!
  • Anonymous Apr 25, 2009
    Same issue for me
  • 2,237 Answers
What's the make and model of the projector? i need more info to sufficiently assist you.
Posted on Dec 23, 2009
5 Suggested Answers
  • 14 Answers
SOURCE: Electrical Problem? Projector works, but buttons don't.
IT MUST HAVE THE CARD INSIDE THE PROJECTOR WHICH IS DETACHABLE LIKE MEMORY/PCMCIA OR ANY OTHER. CHECK USB ALSO.
Posted on Jun 04, 2007
  • 74 Answers
SOURCE: InFocus LP 250 Multimedia Projector
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
Posted on May 11, 2010
jyackle5
  • 8197 Answers
SOURCE: Changed to a HDMI cable back to amp, worked
Your power board in the projwctor has gone out on you. You will need to send in for service.
Posted on Dec 09, 2010
  • 5370 Answers
SOURCE: Hello, Sorry for my bad
Be sure to replace the lamp when the message [Replace with the new lamp.] appears. If you continue to use the lamp after the lamp has reached the end of its usable life, the lamp bulb may shatter, and pieces of glass may be scattered in the lamp case.--------------- POWER Indicator :------When this indicator is green, the projector is on; when this indicator is orange, it is in standby mode.----------- WARNING Indicator:-------- If this light blinks red rapidly, it indicates that an error has occurred, the lamp cover is not attached properly or the projector has overheated. If this light remains orange, it indicates that you have pressed a cabinet key while the Key lock is enabled. ----------- After your lamp has been operating for 2000*hours (up to 3000* hours in Quiet mode) or longer, the LAMP indicator in the cabinet will blink red and the message "Replace with the new lamp."will appear. Even though the lamp may still be working, replace it at 2000* (up to 3000* hours in Quiet mode) hours to maintain optimal projector performance. After replacing the lamp, be sure to clear the lamp counter. Resets the lamp clock back to zero. Selecting this option displays sub-menu for a confirmation. Select [Yes] and press the OK button. ---------- NOTE: The projector will turn off and go into standby mode after 2100* hours (up to 3100* hours in Quiet mode) of service. If this happens, press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp. --------------- Over-Temperature Protection:------- If the temperature inside the projector rises too high, the over-temperature protector will automatically turn off the lamp with the WARNING indicator blinking (2-cycle On and Off.) Should this happen, do the following: - Unplug the power cord after the cooling fans stop. - Move the projector to a cooler location if the room where you are presenting is particularly too warm. - Clean the ventilation holes if they are clogged with dust. - Wait about 60 minutes until the inside of the projector becomes cool enough. --------------] Now as you mentioned that you have replaced the lamp, so did you got original lamp or used or second hand lamp.Only original lamp is advisable.If you got lamp from ebay sites ,then most of the cases they provide used lamp,and in some cases they dont work.In that case new lamp is advisable.But if you got new lamp and still the same problem then check the lamp cover.The cover which you open to remove the old lamp.If that lamp cover is not closed properly then this problem occurs.If the cover is checked ok then other possibility is temp ventilations dirty.Clean the ventilations,check the internal fan is it running or not running.If its not running then fan is the problem.Its stuck with dirt or its got faulty. But if fan checked out ok and all dirt and ventilations cleaned and still the same problem then try reset procedure.Its mentioned above( press the INFO button on the remote control for ten seconds to reset the lamp clock back to zero. Do this only after replacing the lamp.) .Try reset if still the same problem then its faulty circuit board in the projector. ---------- Click this link for user manual:--- http://www.aboutprojectors.com/pdf/canon-lv-7265-manual.pdf --------- This will help.Thanks.Helpmech.
Posted on Mar 14, 2011
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
Acer dlp 1120 show pinkish tint
for acer p1120 pinkish tint solved:
reset your lamp hours
do hard reset :
power off beamer
unplug power cord and press power at same time
replug power cord in beamer and press power button for 10 sec
now it should turn up normal again pink is gone
i called acer also with solution so they can also help you out if you dont get it done
Sep 11, 2013 | Acer P1120 3D Video Projector ACER
Vivitek Qumi Q2 reset ?
Unplug the power cord from projector
--> HOLD down (keep holding down) the right key on the keypad (top of the projector) and Insert the power cord back to the projector
--> The "Power" and "Ready" LED light should blink TWICE and unplug the cord from the projector (while still holding down the right key)
from facebook site
Jan 02, 2013 | Vivitek Qumi Q2 WXGA 3D Ready LED Pocket...
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
May 11, 2010 | InFocus LP 250 Multimedia Projector
Projector not booting up
The projector may not be receiving power or it may be malfunctioning. Turn the projector off and unplug the power cord. Confirm the power cord is securely connected to the projector and then plug the cord back in to a different outlet and turn on the projector. If this does not solve the problem, and another light is on or flashing, check the projector’s status.
Hope this helps
Apr 01, 2010 | InFocus IN24 Multimedia Projector
208 people viewed this question
jasbo
jasbo
