Question about Dryers
Dryer belt how to fix belt on
  • Dryers Master
  • 8,220 Answers
Unplug the dryer
remove the front
drape the new belt around the drum
connect the idler
belt cannot be twisted
Repair photos and service manuals
Posted on Nov 30, 2012
The drum in my Kenmore Electric Dryer mod.100 6062990 will not turn, how do I fix it?
belt,motor, here is a website that will help and the second one is if the belt did break it will show how to thread the belt, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.applianceaid.com/images/belt-config.JPG
Feb 26, 2011 | Dryers
Sounds like a belt went, smelled burning rubber. unplugged the dryer. is a belt easy and cheap to fix?
belts are $10 - take front panel of dryer off and remove drum. install new belt and good to go
Dec 17, 2010 | Estate TEDS740JQ Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Dryer modle #lde9334ace making noise
More than likely it is the belt. A simple fix is to spray some belt dressing on the belt. However, changing the belt would be the best solution. Good luck.
May 18, 2009 | Dryers
HOW DO YOU FIX A BELT ON MY ZANSSI DRYER ZDC46130S
remove back cover off dryer, put belt around drum and drive motor, pull spring loaded pulley back, as it will be resting on drum, feed belt around pulley. and reassemble back cover.
Jan 25, 2009 | Dryers
Need to replace dryer belt for kenmore series 80. The dryer is apart dont know how/where the belt should be installed
hi the belt is attached to motor find below shaft the screws ,fix the belt again assemble it
Sep 10, 2008 | Dryers
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
My belt came off my dryer, Help!
You should have a "tension pulley" that the belt goes around somewhere in the belt track. Usually a "wheel or pulley mounted on a spring" which looks like a flat piece if metal. Check to see if it has come out of its positon or the flat spring has broken. You can buy replacements if it has. Simply reposition the belt and push the tension pulley in such a way as to engage the belt correctly. That should fix it.
Jul 16, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
