Question about Sony KP-57HW40 57" Rear Projection Television
MY screen turns red after the tv set has been on like for 15 minutes
I go turn the tv on, about 10-15 minutes of being on, the picture starts getting red. It use to take a while to get fully red but now it turns red immediately. Can you tell whats the problem and if so is their any live instructions i can watch and follow.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Locate the master screen / Focus block with 6 adjustments and turn the red Screen down a little.
Posted on Dec 22, 2012
SOURCE: Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Posted on Jun 29, 2008
  • 41 Answers
SOURCE: My KP-51HW40 is better, but it still turn itself off
Are you sure you didn't turn the knob too far down? Just a though. I don't know off hand which one is the D board but the boards are marked. Please be careful when working on TV sets as they produce high voltage which may reside even while the sets is unplugged. Also I would do more research on this problem before purchasing a new D board. I have been told that the picture tubes in these sets go bad. G what a bummer guess what set I own :( Here is the code for 8 blinks, it looks like you may just have to replace a part on the D board.
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
I hope this helps, keep in mind its hard to diagnose issues without actually being there.
Posted on Mar 16, 2009
welcomejee
  • 10594 Answers
SOURCE: power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Posted on Jul 09, 2009
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
SOURCE: Hi I have a sony KDP-57XBR2 television set and the
I had the same problem in blue. I took the right front speaker cover off (pops off) and the access panel on the right side 2 - 4 screws. In the upper right corner is a black plastic box with 2 rows of 3 adjustment screws. All I did was turn one of the "screen" screws (not the "focus" screws). Hope this helps. May only be a temporary fix, but good luck...
Posted on Sep 04, 2009
My Tv started with flashing red/orange colors. Then later the screen turned red/orange and the TV shut off. When I attempt to turn it on again, the screen stayes red for a few minutes then shuts off.
The problem based on the model number is in or around the red picture tube---the bright red screen causes the set to draw too much current and the shutdown circuit detects this and turns set off--self protection.
Each picture tube (3) has a IC chip on the board connected to it--shorted chip or bad picture tube.
Shop repair in most cases.
Dec 02, 2012 | RCA HD56W58 56" TV
Sony rear projection kp-577hw40, screen turns red after being on for 10 minutes
This model and some others had bad picture tubes that are no longer available---there is an option here.
If screen gets bright red, green, or blue set will shut down as it detects too much current being drawn.
Seen over 100 with this issue--what can be tried and usually will help is a physical adjustment inside the set.
No parts to replace and takes about 15 minutes to do.
I can tell you how if you want to know.
Jun 13, 2012 | Sony KP-57HW40 57" Rear Projection...
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Screen image turns red after 15 minutes After about 15 minutes the image on the screen will start turning red. After about 5 more minutes the images are nearly all black with highlights...
pick up a can of freeze spray at staples and run you set till it breaks down with the back ooff so you can get at it fast when it fails spray your t-con board locates at the top middle see if it stops doing the symtom you saw. if not spray the mainboard this way you can deturmine which board it failing
Nov 24, 2009 | Televison & Video
WHEN I TURN ON TV I GET A RED SCREEN WITH HORIZONTIAL LINES STAYS ON FOR 10-15 SECONDS THEN TURNS OFF STAND BY LIGHT BLINKS 7 TIMES SORRY THIS IS A SONY KV35V65 TV
this is a red retras line problum
[1] red cathoud video amp. trangester is sort or dry canaction
[2] red cathoud is sorting with filament terminal is in side pictur tube
so pls. cont. your nr. tv. tech. solve this problum. it is not very expancive
* this is a coman problum if your tv set is 7 to 8 year old.
Nov 10, 2009 | Sony KV-32V65 TV
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Screen turns red after 10 minutes
First, lets see exactly what is happening and what is causing it. If your picture starts out fine, and after 10 minutes or so you notice that the picture is getting redder, and the redness slowly gets worse and worse, until finally there is red everywhere with faint curved lines, then chances are your Red Screen control is set just a hair too high. This is a very simply thing to correct. If, on the other hand, the picture is fine for 10 minutes or so and then suddenly flashes very bright red, followed by the set shutting down, then your red picture tube has developed a short in it, usually between the heater and cathode. A good tech might be able to remove the short by arcing. What is your set doing? The KP-51WS500 is one of the newer 16x9 1080i HD sets and the tubes are available from any Sony distributor. When they told you the tubes are not available, that was their way of saying they do not want to bother helping you. The Sony tubes are quite inexpensive, costing about $175, and they come complete with sealed coolant chambers, so replacing a tube is quick and simple.
Aug 31, 2007 | Sony KP-51WS500 51" Rear Projection...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Sony KP-57HW40 57" Rear Projection Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
