Question about Kitchen Ranges
Fan keeps sticking
Will start moving if I use a cocktail stick to move it
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
Back wheel sticking
Its either a sticky caliper on the rear or its in gear .is it stuck all the time or will it move a few feet and then stop quick ? If its stuck all the time id suggest tapping the caliper face with a soft mallet to loosen the caliper pistons a bit . If its moving a bit then stopping then check its in neutral
Mar 13, 2014 | 2011 Piaggio Zip 50
My 2003 Jeep Grand Cherokee Limited seatbelt light is staying on even when hooked together
you may have a sweet or something in the seat belt lock making the switch move out of the way, build up on it makes it move out of the way. may be able to clean out with a cocktail stick or somthing like it
Oct 26, 2013 | 2003 Jeep Grand Cherokee
Dont know how is become when playing soccer my player keeps moving forward without me even controlling
Your analog stick is dirty, where it sits on the motor peg and it's causing your stick to be read as moving instead of standing. clean controller.
Aug 13, 2013 | PlayStation Gioteck Ps3 Sc1 Wireless...
I own a mad catz n64 controller and any time i push or hold any button (b,a, cs) it makes the character move slightly but endlessly to the right side, the control stick works fine, i only got this problem...
To remedy this, simply don't move the analog stick when powering on the system. When the system turns on, however the analog stick is set to be the default center so if it is moved, it is assumed to be the normal center position. If you have accidentally moved it while powering on the system, you can reset it but letting the analog stick reset to center and then press and hold START, L and R at the same time for three seconds.
Jul 18, 2011 | Nintendo 64 Console
New Holland DC 100 Dozer starts and runs but won't move. Bottom left warning light is on and can't find out what it is, there is no symbol on it. Guy who was running it said it was working fine for a few...
WE HAVE NEW HOLLARD DC75 IT WON'T MOVE FOWARD OR BACK BRAKE LIGHT STAYS ON AND SAFTY LEVELER WORK JOY STICK SAY IT IN FOWARD OR BACK BUT NOT MOVING WHAT TO DO?
Feb 17, 2011 | Garden
This is an error in the ink loader.
It usually means the ink count sensors are stuck, after using 2 - 3 ink sticks. Your code shows that the yellow ink loader is stuck.
Features on the bottom of Xerox ink sticks actuate the ink loader sensor located at the end of each ink loader channel. The sensor detects the movement of the ink sticks to keep a record of ink usage.
Damaged, or Non-Genuine ink sticks may not actuate the sensors. Or using older Phaser 8400 model ink will also cause the 9,03x.4x errors.
  1. Check the ink sticks are genuine, and for the correct model.
  2. Manually verify that the ink stick is able to move in the ink loader chute. Check for broken or incorrect ink sticks.
There is a small chance that the ink count sensor is faulty, or the ink heater has blown.
This fault has to be cleared by running the Clear ISC Fault function, in the Service Diagnostics Menu.
Service Diagnostics > Function Menu > Clear ISC Fault
To enter the Service Diagnostics Menu, start with the power OFF.....
1. Turn the printer power On.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold
the Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization. Release the buttons and the printer reboots into service
Have Fun!
May 11, 2010 | Xerox Phaser 8560DN Laser Printer
Ps3 will not start up yellow light then red light
I think the motherboard need a reset ! the probleme look similar to the XBOX. there's a way to reset the box But use it at your own risk , as it can cause permanent damage to your systeme if not apply properly.
and don't do anything without somebody confirming the methode.
It consist in blocking all the fans with a wooden cocktail stick , turn on on box and wait till the systeme overheat then reset itself. then unplug le box , remove the sticks, replug and start the ps3 . good luck and be carefull
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Car wont lock
spray excess WD 40 or similar onto the key whilst moving it in & out of the lock or dribble it down a toothpick/cocktail stick in to the lock or hold the lock open with the stick and spray into the lock barrel
Sep 02, 2009 | 2006 Peugeot 604
I have a 98 Concorde
You need to check the linkage. Under the car, the section that connects the gear shift stick to the transmission rods.
Nov 09, 2008 | 1998 Chrysler Concorde
Psp moving by itself
Hey, looks like your PSP may have one of these two problems. There are 2 screws on the backside of the PSP System on the side of the analog stick. If either of the screw is loose then the analog stick will move by itself.
Second problem is the Analog Stick itself has been damaged. You can replace these very easily if you are good with tools and electronics.
Bimmerhp
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
