Cannot open volumn for direct access - Computers & Internet
  • 27,725 Answers
Are you getting any error messages ?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
for usb drives
Click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it
Hope this helps.
Posted on Dec 01, 2012
I have no sound for incoming calls. I have checked all the volumn settings and they are all turned up as far as they will go. I can talk and hear my party just fine. What can I do.
I have the Samsung Galaxy 4 - I hope that this will help you.
Open SETTING app
At the top of the screen open MY DEVICE
Open ACCESSIBILITY
Move down to TURN OFF ALL SOUND - make sure that it is NO CHECK MARK.
Feb 04, 2015 | Samsung Cell Phones
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
My slider volumn control was deleted. How do I
Go to start button, control panel, sound, when you open sound, you can configure it.
You did not post which windows you have.
You can right click on the bottom taskbar, a little window will open,
click on properties, under the taskbar tab, click custom, and you should see Volume, tell it to place it on the taskbar.
Feb 07, 2010 | HP Computers & Internet
Both volumn and channel buttons will not arrow down
there is a trace broken in the front panel circuit board (where the switches are installed) and the line is open to the microcontroller. this solution can be easy in the workshop. Specially because two other switches work.
Apr 17, 2009 | Emerson EWL3706 37 in. LCD Television
Hot water out line seems to be pluged
make use our cold water feed that is going in to your tank is all the way open
Mar 04, 2009 | Water Heaters
Volumn Control on my 36
I have to turn my volumn to 100 to hear it and the tv is 1 month old.
Mar 14, 2008 | Mitsubishi VS-60603 60" Rear Projection...
I do not have any volumn control
Open the speaker where the volume control is located then check it if there are lose connections. You can also clean the variable resistor or the volume control with a contact cleaner solution or oil... ^_^
Jan 19, 2008 | Yamaha YST-M7 Computer Speakers
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
