Question about Redfield Optics
Elevation and windage seam to be backwards
When ajusting after a shot seam to go in wrong direction
  • 75 Answers
SOURCE: windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Posted on Apr 28, 2009
  • 3 Answers
SOURCE: windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
Posted on May 04, 2009
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
miket756
  • 2702 Answers
SOURCE: new nikon monarch III 4-16x42bdc. elevation is
have you shot it yet???? dont forget bullet drop!!!! but if it shoots to hight thats easy to put right,,,most of the time its a mount fault, but undo the front of the scope mount and slid 3 bits of 35mm film under the scope then nip the scope down on the film strips,,this will lift the point of aim past what you need,,,,
Posted on Nov 27, 2010
wswift
  • 74 Answers
SOURCE: What directions do you turn
Here is a diagram showing all the settings: wswift_5.jpg
Posted on May 17, 2011
Where can i get complete up & down adjustment wheel for a richter optik rifle scope 3=9x50 aoe please
Direct from Richter or a dealer.
And the up and down is called 'Elevation', and left to right is called 'Windage'.
http://www.richterscopes.com/
Sep 27, 2016 | Optics
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
Haveing problem with the windage adjust and elavation adjustment it is working backwards.
If your point of impact needs to move up, turn the knob the direction that says up. If it needs to move left, turn the windage knob the direction that says left.
Jan 21, 2011 | Optics
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Jan 05, 2011 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Adjusting the windage and elevation, seems to be opposite than what the arrows indicate, anyone else have this problem
yep,,,,lots of times,,,,,some scopes tell you were the shot will go,,,some tell you the way your turning the scope to point? it dont help do it?
Nov 28, 2010 | Tasco ProPoint Red Dot Matte Red/Green Dot...
Unable to zero in on target?
take it in because if he bumped the rail the scope is on it can make it inaccurate
Aug 01, 2009 | Optics
Windage and elevation adjustment all over the place
May 02, 2009 | Optics
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Optics Logo
43 people viewed this question
Top Redfield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Redfield Optic Expert? Answer questions, earn points and help others
