Question about Canon EF 50mm f/1.8 II Lens
How do you remove the macro lens - Canon EF 50mm f/1.8 II Lens
  • 685 Answers
The 50mm f1.8 lens is not a macro lens. If you attached a close up filter, it should just screw off. Try not to squeeze the ring too tight as that may make it harder to remove. Also "righty tighty - lefty loosey"
Posted on Dec 15, 2012
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
How to click close macro photos with Sigma 70-300mm f/4-5.6 DG APO Macro Lens?
This lens is not a true macro lens. It provides a magnification of 1:2 only, while true macro lenses provide 1:1 (life-size)magnification. So you won't be able to do very close macros with this lens. This lens has a Macro switch to enable you to switch to the Macro or normal mode.
May 12, 2010 | Sigma 70-300mm f/4-5.6 DG APO Macro Lens
Cannot figure out how to take good macro shot with new Tamron len
With an SLR you only get true macro focussing on a lens that has proper macro focussing abilities. Unfortunately in the photogaraphy world, there are a huge number of lenses which claim to have macro ability but are stretching the term far too much.
Strictly speaking, macro means that the lens is capable of producing images on the sensor which are the same size as the actual subject or even bigger, at life size this is described as 1:1 macro. Your Tamron lens is only capable of a maximum 1:3.7 "macro", and that's only at the 200mm zoom setting with the subject no closer than 45cm from the lens. By SLR zoom lens standards, that's actually pretty good, but if you want to go closer and get greater magnification you need to either use a supplementary close-up filter lens or for better optical quality use a set of extension rings. The trade off with close up filter lenses is poor image quality and usually plenty of colour fringing and with extension rings is that if you're using a 2x magnification at 200mm, your f5-ish maximum aperture at 200mm becomes a very dark f10.
The only way to get good macro results is to either use a proper (=expensive) macro lens and excellent lighting, or use extension rings plus a good ring flash unit. However you can improve your macro by investing in a more capable zoom lens with a closer minimum focus distance and a better aperture at the telephoto end of the range. This can be expensive, or you can pick up some very cheap 35mm film SLR lenses. Using an adapter will never allow you to achieve infinity focus on a Canon digital SLR but you can get a close focussing 200mm f3.8 very cheaply. The crop factor of your smaller sensor means it will have the same angle of view as a 310mm lens but the aperture will remain at f3.8. As Canon digital SLR's have the deepest body register (lens to sensor distance) of the current systems then you'll also have the effect of using it on an extension ring. The downside is that you'll have to use the lens in a totally manual mode as no information will be communicated to your camera body. By mounting the lens back to front using a reversing ring you can achieve some really stunning macro magnifications but then you need a tripod, powerful flash and absolutely no wind... There was also a Makinon 80-200mm zoom which sells for next to nothing on auction websites, but it had a macro collar which allowed it to achieve around half size macro (1:2).
Alternatively, if the Fuji still works and does the job just keep it in your camera bag ready for those types of shots. overall, that seems the easiest and best solution unless you really want to get heavily into macro shooting.
I hope that I've helped you, please ask more if there's anything unclear. I've tried to keep a very complicated subject as simple as possible. Please also take a moment to rate my answer.
Mar 05, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Zuiko 70-300mm lens focusing problem
Haha!!
Maybe its something you're not doing, LOL.
Look on the side of the lens. Most of the 70-300 macros have a slide switch. My Tamron, for instance, needs to be zoomed out to 300, then slide the switch to Macro and its ok. Look for the slide switch. You might also notice lines of a different color to denote Macro.
Some days it too tough to be smarter than the lens,
LOL.
Dec 31, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
I can't get the macro adapter to work ?
Put the macro adapter on the camera and move the camera in and out from an object to try to focus the object in the display. Remember, macro is very small, very close and very small field-of-focus. I hope this helps.
May 28, 2009 | Vivitar Telephoto 100mm f/3.5 Macro Manual...
Nikon D40 I bought a set of macro lenses that said they were compatible for the d40 but i cannot figure out how to fit them. They are 52mm lenses - should i have bought an adaptor or something? where...
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
Dec 22, 2008 | Nikon Cameras
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Macro mode
The lens shade is blocking light from the built-in flash, remove the lens shade.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Canon EF 50mm f/1.8 II Lens Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
