Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 propane to natural gas conversion.
I already have the the 4 stove top orifices changed but how do I change over the oven for baking, this is a GE XL44 Model.
  • 1 more comment
  • rbills May 04, 2009
    WHERE DO YOU GET THE KIT TO DO THIS FOR THIS STOVE?
    We want to convert our GE XL44 gas stove to natural from propane.
  • aarons557 May 18, 2009
    How much does the hood/orifice on the oven and broil burner need to be loosened? Just broken free or multiple turns? I have a Profile Spectra range.
    Thanks.
  • Anonymous Mar 23, 2014
    My GE Spectral XL44 self cleaning gas oven losses temperature as it is baking and I have to keep turning it off and back on again to get back to the temperature. What could be causing this.
    President:
  • GE Master
  • 2,651 Answers
Your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
  • Joe Viscusie Nov 05, 2011
    i had the same problem when I made the conversion. Loosened the hood 3/4 of a turn problem solved.
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
How do I switch propane to natural gas on the stove
all 6 of the orifices 4 on top and 2 in the oven 1 for bake and 1 for broil have to be changed get the correct orifices the propane orifice opening is smaller and the natural gas opening is larger replace all of those and you are ready
Apr 03, 2010 | Magic Chef 31000 Gas Kitchen Range
Hi, You will need to use a 1/2" wrench and turn the orfice for the oven 2 turns counter clockwise.
Make sure you flip the plunger over on the regulator also.
After doing these things, watch the flame in the oven to make sure no other adjustment is needed.
Please let me know if this helps or if I can assist you further.
Vic
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Whirlpool SF325 Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
2,544 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
