Question about Hitachi 70VS810 70" Rear Projection HDTV
My Hitachi 70VS810 is making a rattling noise when the set is turned on. The picture is fine but the noise is constant.
I was told that it could be the color wheel or the light engine. Is there any other possible cause? I removed the rear panel but am unable to determine the source of the rattling.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If its the wheel that part faces the lamp.
My Hitachi 70VS810 is making a rattling noise when - 12_22_2012_2_09_11_pm.jpg
Posted on Dec 22, 2012
ctf1800
  • 4402 Answers
SOURCE: hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Posted on Jan 04, 2008
ctf1800
  • 4402 Answers
SOURCE: Hitachi 51F500A, 51" rear projection.
it's going into protection mode.
first thing i would try is replacing the convergance ic's
Posted on Jan 10, 2008
SOURCE: Hitachi 51F59A Color/Dark problem
Could be the blue CRT shorting out. I had the same problem but with red. Eventually it shorted out completely. If it is only 2.5 month old it should still be under warranty and they will fix it.
Posted on Feb 27, 2008
freetek
  • 5568 Answers
SOURCE: Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Posted on Feb 28, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
Waht would cause a loud rattleing noise in my engine?
get it into a garage before something really goes bad then you'll be looking for a new beamer
Apr 29, 2014 | BMW 325 Cars & Trucks
Have a ultra vision 70vs810 it blinking red and
I tried all of the above and no luck but THEN we realized we had it plugged in to the surge protector not the battery backup. Once we plugged it in to the battery backup it powered up like a champ! Good luck!
Jul 31, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
The power is on , no pictures or sound. Blank screen.
sounds like a bad lamp most lamps are rated at 2000 hours hope this helps ya
Apr 14, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
I have a Hitachi 70 inch lcd rear projection tv (70vs810). When the tv is turned back on the screen is very blurry. We have had a problem with it over the past 6 months but it would go away after warming...
This is a well described problem with model #. Thanks for that. Now it could be a tv lamp at the end of its life if the tv lamp is around two years old. Its easy to change lamps and the procedure is explained in owner's manual. If the lamp was replaced recently or the problem stays even after changing the tv lamp, its the optical block going bad. That need professional help and you should not try to mess with it. Check out at www.fixurtvs.com These repairs could be expensive and may be wiser to go in for another TV.
Feb 26, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
I recently moved and when I powered up my Hitachi model 70vs810 the temp light is flashing and the tv won't light up
it sounds like theres something wrong with your tvs air filter.
my advice is to take it to the store you got it from and ask them if theres anything they can do
they should be able to clean
i really wouldnt sujust trying to get it out your self it can be tricky putting back togther
Nov 09, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
My Hitachi 70" LCD will not turn on
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Feb 04, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Won't turn on?
You need to check the lamp itself,sometimes they just blow up like a bulb does and if the lamp is good make sure all the fans are running and all compartments are close properly like where the lamp sits.Set needs to be unplug from the wall while you check.The wainting is not acceptable for 3 months.Let Us know if you need more information.
Oct 10, 2006 | Hitachi 70VS810 70" Rear Projection HDTV
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
157 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
