Question about Char-Broil Charcoal Water Smoker 4654301
Frustrated-please help !!!!!!!!!!!!!!
Having difficulty maintaining heat in the ideal range on the gauge and cooking food up to temperature. we have to finish things in the oven. Gauge stays in the warm range. We do know that the gauge does work because we lit behind it with a lighter and it moves fine up to hot range. once the charcoal is in white ash range, we add more charcoal like it says in the instruction manual and open little door. We can see the flame but the gauge never gets up to ideal range. please help
  • 1 more comment
  • Russk Nov 22, 2007
    Do you drill holes above or below the charcoal pan line for a better air flow? Where exactly should the holes be , how many and how big? Thanks
  • chris Mar 29, 2014
    I drilled the air holes in the botom (4) of the charcoal pan and the holes fo
    I drilled 2 holes in the side of the pan & 2 more directly across about 2 inches from bottom and put threaded rod thru them and nuts on each to keep in place to hold the charcoal grate
I have the charcoal brinkman smoke n grill, had the same problem until i found brinkmansmokermods.com
the grill they are working on is a little different from mine but i used the same idea and added 4 holes in the bottom of the charcoal bowl with a 9/16 bit. This will fix your temp problems but will give you another one......the charcoal ash falls on the ground. To fix this i went to Lowes and bought a 24" water heater pan to sit the grill in to catch all of the ash.
Also I found the weber charcoal grate at my Ace Hardware here in Cypress Tx.
Good luck!!
Posted on Jun 21, 2009
  • 35 Answers
The problem is that you are not getting enough air into the smoker. What you need to do is drill some holes along the bottom of the smoker to let more air in. This is a notorious problem with that smoker
Posted on Nov 04, 2007
  • Kamuela Pelletier Dec 03, 2007
    You drill the holes along the bottom, below the pan. As for how many and how big, it's just a trial and error type of thing. I would use a quarter inch bit and space the hole out evenly until you can maintain temperature. Sorry so long for a response
Forget the charcoal and place an electric hot plate in bottom. the cord will fit through air holes. put the soaked wood chips in a castiron skillet, then place the hot water pan above it
Posted on Mar 23, 2008
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Sep 15, 2010 | Crock Pots & Slow Cookers
I have a Chef Ceran Cooktop Model EHC64oU with four elements. The problem is that it doesn't seem to cook anything on a low heat. It stays on low for a few minutes and then the the temperature increases...
I am assuming having looked up the model that you have a glass top range. These ranges use a thermostat to regulate cooking temperature, and when they go bad you will either suffer from erratic cooking temperature or have no heat at all. The best solution I can think of is to replace that thermostat.
Aug 05, 2010 | Cooktops
Uneven cooking food has to be turned every 10 minutes, bottom of food burns and top dosent cook
How does the food know which way its facing?
Try covering the food with a lid from a smaller pan.
And always remember...to cook faster, sometimes you have to cook slower! A carbon layer on food acts as a heat shield against further cooking!
Dec 09, 2009 | Baumatic BT2395SS Gas Kitchen Range
Ronson slow cooker settings
Hi. I'm a Ronson Service Centre in Australia.
I grabbled this blurb from a Ronson Slow Cooker Manual.
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Nov 24, 2009 | Crock Pots & Slow Cookers
I can not change temperature to more than 41f. Lower temperatures are OK
Temperature is perhaps the most critical means of control in the prevention of foodborne illness. Harmful (disease-causing) microorganisms grow within a temperature range of 41 F to 140 F (referred to as the "Temperature Danger Zone"). Many foods, especially raw animal products, naturally contain harmful microorganisms. Keeping foods out of the Temperature Danger Zone prevents disease-causing microorganisms from growing in foods. Proper cooking and reheating of food is important because heat destroys disease-causing microorganisms that may be present. Ensuring proper heating and storage temperatures is essential for assuring safe food in retail operations. Temperature guidelines differ depending on the type of food and method of heating method.
Freezing
Most pathogenic microorganisms will not grow below 41 F, or their growth will be very slow. However, many spoilage microorganisms (which cause foods to taste and smell bad) can grow at temperatures well below 41 F. Most foods that are frozen in food retail are done to improve quality and increase the shelf- life of the product. Most foods will freeze at about 28-30 F. To ensure safe freezer temperatures, be sure that your freezer is maintained at least 28-30 F or below (foods should be frozen solid). Ideally, foods should be frozen at 0 F or below to maintain quality.
It seems that your Refrigrator's higgest point is set to 41 F
Jun 19, 2009 | Refrigerators
Ronson slow cooker don't know which is high or low
on setting 1 (low),the slow cooker can operate all day and night if required
when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
bianca
Jun 12, 2009 | Crock Pots & Slow Cookers
Lost Manual - not sure which is high or low
Hi. I'm a Ronson Service Centre.
I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
Mar 15, 2009 | Crock Pots & Slow Cookers
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the...
Hello Michael Smith,
You MODEL number only came through as a
PARTIAL ... (so I filled in the rest (assuming USA)):
RGB745 ... wea2ww
Please note:
Accordingly... you will have to VERIFY the part.
Part and video guidance are available here:
Third item on the page "heat sensor"
http://www.appliancepartspros.com/parts-for-ge-rgb745wea2ww.html
Hope this helps...
Carnac the Magnificent
Aug 13, 2017 | Hotpoint RGB745 Gas Kitchen Range
Char-Broil Charcoal Water Smoker 4654301 Logo
819 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Steve Allison
Steve Allison
Dave Cottrell
Dave Cottrell
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
