Question about Samsung WF337AA Front Load Washer
Won't spin out
    Top Expert:
  • Samsung Master
  • 9,472 Answers
First, check to see if the drain filter is clear. Post back the results.
Posted on Nov 30, 2012
2 Suggested Answers
SOURCE: Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Posted on Apr 26, 2012
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
Disney d-style karaoke won't read disk or spin disk
The problem is in the laser pickup assembly, the pladder motor is not working that spins the disk, and unfortuneately the only way to correct this is to replace the entire assembly which probably won't be cost effective.
Mar 06, 2012 | Televison & Video
Truck has electrical power but won't turn over. I think I can hear the starter solenoid engaging. Not sure. where do I start trouble shooting?
Safety first!--Make sure you're in park & brake on-- Try shorting across the starter terminals with a screwdriver,if the bendix kicks in & nothing spins,remove the starter & put in bench vice ,(or hold down securely), & jump with cables.--REMEMBER POLARITY--If the starter spins you are in deep *******---something in the motor is probably locked up.(If the starter doesn't spin get a new one.)
Sep 24, 2011 | 2007 Nissan Xterra Off Road
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My washer will not spin, it sounds like it's trying to spin but it won't spin and if i turn the barrell by hand it spins so it's not frozen or anything. Any suggestions?
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Samsung WF337AA Front Load Washer Logo
420 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
