Question about Samsung Yp-U6ap U6 4Gb Mp3 With Fm Radio And Usb Slide - Pink
My samsung ypu6 mp3 player suddenly won't switch on and it blinks when I try to charge it. Please help.
I charged it when the battery was empty. Now it won't turn on.
    New Friend:
Posted on Apr 02, 2013
SOURCE: Samsung KP-K3 MP3 Player - Charging battery
wen i first got myn i had the same problem i plugged it and left it plugged in for a couple of hours and it showed there bars and was fine i dont quite no wat i did but i suggest double checking you have plugged it in prople sorry if im no help x
Posted on Oct 03, 2007
SOURCE: WONT TURN ON!!!!
Why don't you just take it to Best Buy2.gif or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 26, 2007
SOURCE: Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
Posted on May 10, 2008
dragonclu
  • 3 Answers
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Posted on May 13, 2009
SOURCE: Samsung YP-K3 MP3 player will not turn on?
Hi.. just had the same problem a few minutes ago and found a solution posted by preciouss_me from the other link..so i tried it and it work. I did reset the button at the back and whoala! it turned on and no files have been deleted..i hope it works for you too. thanks!
Posted on Oct 28, 2009
The charger works but it does not full my battery it always says that low battery though i charge it for an hour..
Try charging it up overnight.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 30, 2012 | Creative Labs Zen Micro MP3 Player
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
Hi I just recently charged up my mp3 player after a long time it's charged but lock screen won't come off I hit the reset still no success
Hello if you see light the back light turned on and see nothing on the screen that mean the frame-wire is damaged and you need to buy new mp3. Or maybe the battery is not working change it as soon as possible and explain to the shop what is the problem. Please rate my comment
Nov 20, 2011 | Samsung Napster YP-910 MP3 Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
I believe the mp3 player's charge to last for 15 hours. It is only holding a charge for about 5 hours
Ifthe recharageable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 26, 2011 | SanDisk Sansa Clip MP3 Player
Battery goes dead right after charging
By experience I know that problem...some might suggest you to change the charge wire?I don't thing it would help.
try to reset your mp3 player or you might have to dissamble for 10 mins then close it back...
Oct 07, 2008 | Samsung Yepp YH-J70 Digital Media Player
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Jul 29, 2007 | Toshiba gigabeat S MP3 Player
Samsung Yp-U6ap U6 4Gb Mp3 With Fm Radio And Usb Slide - Pink Logo
394 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
