Question about Nikon COOLPIX P100 Digital Camera
Camera turns off automatically to prevent overheating
The overheating warning appeared and the camera turned off. Left camera off overnight but still won't turn on. \was out in rain and may have received moisture.
  • Chris Hore Dec 02, 2012
    Should also mention that I removed the battery and memory card, loightly dried with a hair dryer and have left it to air out for about a day and a half now. When re-inserting the battery it the camera now does absolutely nothing. Yet it shows itself charging (light blinks) when camera is plugged into charger.
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
t00nz
  • 4738 Answers
SOURCE: dropped camera while it was
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Dec 25, 2010
8ushy
  • 109 Answers
SOURCE: Everytime I turn on the camera, the lens start to
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Regards 8ushy
Posted on Jan 04, 2011
dcramer531
  • 1654 Answers
SOURCE: The camera ran out of
Unless the batteries are in wrong they must be dead. try to use new ones and check for the instalation some of these cameras use wierd configurations on which is positive and what is negative.
Posted on May 25, 2011
Testimonial: "What can I say. It was the most obvious solution but did I think of it? No. Thanks heaps."
hiddenul
  • 313 Answers
SOURCE: The camera was exposed to
Hello. Please follow these 5 easy steps:
1. The most important of all, DO NOT try to start your camera.
2. Loosen the battery cover, remove the battery and put it somewhere to dry.
3. Wipe the camera immediately with a paper towel or anything that absorbs water well.
4. Use a powerful vacuum to absorb the water droplets which you can't reach with a towel (such as those inside the case).
5. Put the battery and the camera in a bowl of uncooked rice by covering it completely. The rice absorbs the moisture from the air very well so that it will help drying your camera. Keep it there for 24 hours or so.
I hope it helps!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
Tip by hiddenul.
Posted on May 30, 2011
My acer 5315 turns itself off occasionally with no warning. looked at the power settings , no problem there
Is it overheating, and then automatically shutting itself off, to prevent the heat from causing damage?
Turn it off. Disconnect the AC power. Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from inside it,
because a layer of dust is acting like an insulating blanket, i.e., retaining excess heat.
Apr 01, 2011 | Acer Aspire 5315 Notebook
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
Computer automatically powers down with out warning
It could be overheating, and shutting itself down, to avoid heat-related damage.
Turn the computer off.
Disconnect the AC adapter.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job" -- shooting compressed air everywhere "inside" your laptop, to remove dust.
The dust is acting as an insulator, preventing your computer's fans from cooling itself.
Or, take your laptop to a qualified computer technician, for more trouble-shooting.
Jan 24, 2010 | Gateway M-1628 Notebook
E18 appears in lower left part of screen when camera is turned on
The E18 error is fairly common on certain Canon models. Here's a link to information on what usually causes it and how to fix it. http://www.e18error.com/
Apr 04, 2009 | Canon PowerShot A85 Digital Camera
Computer shutsdown unexpectedly
It sounds like it is overheating. Take the side off the case and see if your CPU fan works. Replace any fans that do not work or feel loose. And while you are at it, take a can of air and blow the dirt out of it.
Leaving it off overnight will not prevent it from overheating. A computer can overheat in a matter of seconds under the right circumstances.
Feb 16, 2009 | Sony VAIO PCV-W600G PC Desktop
The AT warning light turned on, and i dont what it means
automatic trans light indicating a problem with tranny could be simple fluid needs to be added or sensor is picking up line pressure issues or overheating check the trans dipstick fluid should be red and not smell like its been left on the stove too long
Jul 21, 2008 | Mazda MAZDA3 Cars & Trucks
Batter won't hold it's charge if left in the camera overnight
Apparently you shouldn't leave the battery in the camera when you're not using it - the on/off switch doesn't turn the thing off completely. Weird!
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Camera stays on
this sounds like a systemic problem. (responding to 3 different inquiries with similar complaints)
the light stays on when writing to mem to warn/prevent you from losing images which happens from premature power down actions.
in this case you have signs that the mother boards are bad. call canon for advice,but i am sure they will instruct you to ship them for service. aside from damaging your camera, it does not sound like a user interaction issue.
good luck
mark
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
My camcorder is turning off by itself.
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 If your camcorder is left in Record-Pause or Play-Pause for several minutes, it turns off automatically to prevent wear on your tape. Set the CAMERA/OFF/VCR switch to OFF and then to CAMERA or VCR to turn it back on.
Sep 06, 2005 | RCA CC-432 Camcorder
Nikon COOLPIX P100 Digital Camera Logo
382 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
