Question about ASUS M50VC-AP012C Notebook
M50vc recover wireless
Wireless has stopped working the F2 key will not start off the wireless network Explorer via cable to router works Ok Suggestions how to turn wireless back on please
  • ASUS Master
  • 7,627 Answers
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Posted on Nov 30, 2012
word2thewhys
  • 42 Answers
SOURCE: Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
Posted on Jan 04, 2009
  • 21 Answers
SOURCE: eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
  1. To open a command prompt, click Start and then click Run. Copy and paste (or type) the following command in the Open box and then press ENTER: cmd
  2. At the command prompt, copy and paste (or type) the following command and then press ENTER: netsh int ip reset c:\resetlog.txtNote If you do not want to specify a directory path for the log file, use the following command: netsh int ip reset resetlog.txt
When you run the reset command, it rewrites two registry keys that are used by TCP/IP. This has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys: SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
Posted on Mar 19, 2009
  • 5 Answers
SOURCE: i got eee pc 900a but wireless not working i try
  1. Turn off your computer
  2. Turn it on and immediately begin rapidly pressing F2 by itself
  3. Go to the Advanced tab by pressing the right arrow key once
  4. Go to onboard devices configuration by pressing the down arrow key once, then pressing Enter
  5. Go all the way down to Onboard WLAN by holding down the down arrow key until it is selected
  6. Press the minus key (-)
  7. Press F10
  8. Press Enter when it asks you to save configuration changes
If that still doesn't work, make sure you have the drivers you need from here:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Posted on Apr 28, 2010
  • 4 Answers
SOURCE: my asus eee won't connect to the internet via wireless
go to start and go to control panel,
then click on internet options, click on the advanced tab, and click reset, there you will find connectivity or internet or something, click on the cross which brings more info up, it should bring up atheos ethernet, and atheos wireless, delete/uninstall them both. then try to connect again.. should work.
Posted on Jun 26, 2010
  • 9 Answers
SOURCE: ASUS N50V FnF2 stopped working.
Dun worry. I experienced that before.. There is a physical wireless slide switch at the right of the indication light. switch it on first and see if it works.
Posted on Sep 02, 2010
Cant get my netgear to work at all. tried re setting it and it stil wont work
to configure the netgear router. . . . 1, first make sure that your laptop is connected directly to the netgear router via ethernet cable. 2. after securing step 1, on your computer, open browser, ( internet explorer or firefox ) 3. go to the address bar, the one with the http:\\ and erase everything inside it. 4. type in there, 192.168.1.1 or www.routerlogin.net. 5. username is " admin " password is " password " 6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard. 8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key and make sure its 8 characters long. 9. the network security key is the " passphrase " then click apply. then your all set for wireless connectivity.
Aug 31, 2011 | NetGear WNR1000 Router
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
I am using time warner cable high speed internet. and trying to connect my ps3 through a belkin router but it is not working. the wireless icon pops up from the router but what is a WPA Key??? HELP!!!
WPA === Wireless Protected Access
It's a level of encryption between the router and each wireless device, to add "security" to your wireless traffic.
Use an Ethernet cable to connect the network-port on a computer to one of the LAN ports on the router.
Restart the computer.
Start Internet Explorer, and connect to the web-server "inside" the router.
From this web-interface, you can set an SSID and set the encryption-level (e.g., WPA) and you can set a password/pass-phrase/pass-key for your wireless network.
Use the same SSID and password on your PS3.
Aug 29, 2010 | Computers & Internet
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
Can't log on to my wireless router becase I forgot my network key. How can I change it?
connect to your router with a network cable and regenerate a new network key under wireless setup.
You dont need a wireless key to connect over a cable
Feb 28, 2010 | Computers & Internet
Wireless
You also might want to check that your wireless hardware switch is turned on. Press and hold down the "function" key on your keyboard, then hit the F2 key.
-Glenn
http://mysticsofthechurch.com
Jan 03, 2010 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
No network code for router want to connect my laptop to it
Hello friend,
i guess that you are talking about wireless code, in this case you will need to connect the laptop to the router via Ethernet cable to configure it and then unplug the cable and use the wireless.
so you connect the ethernet cable between the laptop and one of the ports on the router from 1 to 4. then access to the router web interface which is usually 192.168.1.1. then go the wireless tab and name your wireless access point and put a password to secure your network. After that you can unplug your Ethernet cable and use the wireless on your laptop to connect your router wirelessly.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G Broadband Router
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
ASUS M50VC-AP012C Notebook Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
