Blue Screen Comes during windows installation 0x0000007b, 0xf9d04524, 0xc0000034, 0x00000000, 0x00000000)
There is blue screen comes during installation of windows xp. run chkdsk/f show in blue screen. i have changed all the setting of bios, change hdd cable, hdd, ram, processor. but problem is still.
  • Computers & ... Master
  • 5,660 Answers
Computer unplugged from power, Anti-Static Precautions FOLLOWED, remove the CMOS battery.
Press the Power On button in, and hold it in for a count of 10 seconds. Count, 1001,..1002,..1003,..etc. Let go of the Power On button.
Do this same procedure two more times. Now reinstall the CMOS battery. (Positive -> + sign on battery always goes UP)
What you are doing is clearing CMOS Error Codes. Now try again.
Also make sure in BIOS Setup utility, and in Boot Options, that you set the first boot device to CDROM.
Plus, is the HDD cable plugged in correctly? Some of the cables do not have a Locating lug on the connector, for an IDE (PATA) data cable.
The faint red stripe on the side marks Pin 1. Pin 1 ALWAYS goes toward the power cable connection, on the harddrive.
Pin 1 is usually marked on the motherboard connector. (You also want IDE 1, or Primary, for the motherboard connector)
http://en.wikipedia.org/wiki/File:Nappe.svg
http://en.wikipedia.org/wiki/Parallel_ATA
SATA data cable can be plugged into ANY SATA data connector, on the motherboard. BIOS will find the SATA device.
Regards,
joecoolvette
Posted on Nov 30, 2012
Blue screen after windows defender offline
For blue screen error, get support from http://www.windowspasswordsrecovery.com/articles/win8/windows-8-1-blue-screen.html
Apr 09, 2014 | Dell Inspiron 560 PC Desktop
Error code for apire 5315 0x0000007b,0xf7c21528,0x0000034,0x00000000
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Dec 04, 2012 | Acer Aspire 3000 Notebook
How can I fix this blue screen error STOP: 0X0000007B (0XF7A4F524, 0XC0000034, 0X00000000, 0X00000000, on my DELL Optplex 320 desktop using Win XP? Will appreciate your input
Maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and ended up with eliminating it. Hope it helps with your case. Regards
Jun 07, 2011 | Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even...
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
Jul 08, 2010 | Microsoft Windows XP Media Center Edition...
BOOTMGR is missing Ctrl + ALT + DEL I have ADVENT Notebook I have connected up A disk Drive via USB I have booted up with XP Home Edition it starts to load files then the Blue screen pops up to say that ''...
this error can come if ur pc doesnt supports windows version thats why i recommend u to change the version of windows u r installing.
if this doesnt work then mail me at aquif@in.com ,bcoz the next technique is much more advanced.
Mar 29, 2010 | Computers & Internet
STOP: 0x00000034 blue screen error... says to disable bios memory options such as caching or shadowing but I can't access windows it keeps restarting and going back to blue screen..... safe mode dont work,...
This is a cache manager error or a missing DLL file error. This might have heppend as a result of some hardware of software changes that you might have made recently. You can either install the removed drivers once again or need to run a repair reinstall of windows to get the curropt dll files working again.
http://www.jj54.com/Fix-Error-Number/0x0000/
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 19, 2010 | Microsoft Windows XP Professional With...
They appear some blue screen 0x0000007B in laptop Acer Intel atom?during the installation of windows xp?how can i rapair this kind of problem?
yes, you need to install a special, Aspire One version of XP. This is a driver issue generally. You must either use the install DVD from Acer or get a specially made version with all necessary drivers built in. Format the Drive and reinstall windows. from that media.
Feb 16, 2010 | Acer Aspire One PC Notebook
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
My Dell PC has a blue screen
Run your pc from windows startup disk, when you get a bleu screan asking :
  1. press enter to install...
  2. press R to repaire...
  3. press F3 to qiut...
press inter, and wait if you get a messege, you already have a windows instaled c:windows...
press r to repaire,,,
then press R and when you finish don't run any program till you install antivirus and scan your pc.
else your windows cant be repaired, you shoud install windows again.
Nov 30, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
